Cannot get token from the Xiaomi Gateway (Hong Kong version)
Hi all,
Thanks for your time/help in advance. I’m looking for a way to get the LAN Communication Token (16 characters) from Xiaomi Gateway (Hong Kong version). I can retrieve the token in the China version using the official XiaoMi app (I got some previously and I’m still allowed to reset the token).
In the China version, I can use the official XiaoMi App in iOS to get the token: i) go to “About”, ii) click the blank areas 3 times.
However, for the Hong Kong version I bought, the “About” option is gone in the same APP, note:
  1. I connect the Gateway (Hong Kong version) in the region “Hong Kong”
  2. the Gateway failed to initiate if in the region “China” (that means I do not even have a chance to try if I can go to “About” page)
Given the above do not work, I have tried the following link (which I think is quite comprehensive). I could get a 96-character token via iOS backup but have no clue how to get the 16 character token I need.
The link: https://github.com/jghaanstra/com.xiaomi-miio/blob/master/docs/obtain_token.md
Appreciate if anyone can share any experience.
Looks like the HK version of gateway doesn’t allow LAN control at all. So in order to integrate with HA you probably need to stick with the China version.
