I have spent a few hours now trying to implement Traccar and get a device_tracker to show up in HA but to no avail. I have installed the Android Traccar app and it communicates successfully with the HA Traccar Server Add-on using http://[redacted].duckdns.org:5055
Port 5055 is forwarded on my router to 192.168.1.104 (HA “Blue”)
HA Add-on Traccar installed
Logs:
You are running the latest version of this add-on.
System: Home Assistant OS 7.2 (aarch64 / odroid-n2)
Home Assistant Core: 2021.12.10
Home Assistant Supervisor: 2021.12.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] mysql.sh: executing...
[cont-init.d] mysql.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] traccar.sh: executing...
[cont-init.d] traccar.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[01:34:59] INFO: Starting Traccar server...
2022-01-26 01:35:01 INFO: HikariPool-1 - Starting...
2022-01-26 01:35:02 INFO: HikariPool-1 - Added connection com.mysql.cj.jdbc.ConnectionImpl@33fe57a9
2022-01-26 01:35:02 INFO: HikariPool-1 - Start completed.
2022-01-26 01:35:02 INFO: Clearing database change log checksums
2022-01-26 01:35:03 INFO: Successfully acquired change log lock
2022-01-26 01:35:03 INFO: Successfully released change log lock
2022-01-26 01:35:03 INFO: Cannot load service: liquibase.parser.ChangeLogParser: liquibase.parser.core.json.JsonChangeLogParser Unable to get public no-arg constructor
2022-01-26 01:35:04 INFO: Cannot load service: liquibase.parser.ChangeLogParser: liquibase.parser.core.yaml.YamlChangeLogParser Unable to get public no-arg constructor
2022-01-26 01:35:06 INFO: Reading from traccar.DATABASECHANGELOG
2022-01-26 01:35:06 INFO: Cannot load service: liquibase.hub.HubService: Provider liquibase.hub.core.StandardHubService could not be instantiated
2022-01-26 01:35:06 INFO: Successfully released change log lock
2022-01-26 01:35:09 INFO: Operating system name: Linux version: 5.10.91 architecture: aarch64
2022-01-26 01:35:09 INFO: Java runtime name: OpenJDK 64-Bit Server VM vendor: Alpine version: 11.0.13+8-alpine-r0
2022-01-26 01:35:10 INFO: Memory limit heap: 512mb non-heap: 0mb
2022-01-26 01:35:10 INFO: Character encoding: UTF-8 charset: UTF-8
2022-01-26 01:35:10 INFO: Version: 4.15
2022-01-26 01:35:10 INFO: Starting server...
2022-01-26 01:35:10 INFO: jetty-10.0.7; built: 2021-10-06T19:34:02.766Z; git: da8a4553af9dd84080931fa0f8c678cd2d60f3d9; jvm 11.0.13+8-alpine-r0
[01:35:10] INFO: Starting NGinx server...
2022-01-26 01:35:11 INFO: Started o.t.w.@1f39269d{/,null,AVAILABLE}
2022-01-26 01:35:11 INFO: Session workerName=node0
2022-01-26 01:35:12 WARN: JAXBContext implementation could not be found. WADL feature is disabled.
2022-01-26 01:35:13 INFO: Started o.e.j.s.ServletContextHandler@1c8e2850{/,null,AVAILABLE}
2022-01-26 01:35:13 INFO: Started ServerConnector@618ff5c2{HTTP/1.1, (http/1.1)}{localhost:18682}
2022-01-26 01:35:13 INFO: Started Server@35e2b89f{STARTING}[10.0.7,sto=0] @14575ms
2022-01-26 01:35:14 WARN: No systemd support - Unable to load library 'systemd':
Error loading shared library libsystemd.so: No such file or directory
Native library (linux-aarch64/libsystemd.so) not found in resource path (tracker-server.jar) - UnsatisfiedLinkError (... < HealthCheckService:40 < Main:111 < *:132 < *:106)
2022-01-26 01:35:28 INFO: [3d6276ac] connected
2022-01-26 01:35:28 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:35:28 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:35:29 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:34:58, lat: 49.17576, lon: -122.97065, course: 90.0, accuracy: 4.9
2022-01-26 01:35:36 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:35:36 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:35:36 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:35:36, lat: 49.17579, lon: -122.97071, speed: 0.8, course: 305.2, accuracy: 13.5
2022-01-26 01:36:08 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 504f5354202f3f69643d3134333833372674696d657374616d703d31363433313839373638266c61743d34392e31373537363233266c6f6e3d2d3132322e393730363532372673706565643d332e323535353439353739303332353034452d372662656172696e673d3334342e3030353237393534313031353626616c7469747564653d2d31332e39303030303035373232303435392661636375726163793d342e39303030303030393533363734333226626174743d382e3020485454502f312e310d0a436f6e74656e742d547970653a206170706c69636174696f6e2f782d7777772d666f726d2d75726c656e636f6465640d0a557365722d4167656e743a2044616c76696b2f322e312e3020284c696e75783b20553b20416e64726f69642031303b20564f472d4c3034204275696c642f485541574549564f472d4c3034290d0a486f73743a206272756e742e6475636b646e732e6f72673a353035350d0a436f6e6e656374696f6e3a204b6565702d416c6976650d0a4163636570742d456e636f64696e673a20677a69700d0a436f6e74656e742d4c656e6774683a20300d0a0d0a
2022-01-26 01:36:08 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:36:08 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:36:08, lat: 49.17576, lon: -122.97065, speed: 0.0, course: 344.0, accuracy: 4.9
2022-01-26 01:36:39 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:36:39 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:36:39 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:36:39, lat: 49.17576, lon: -122.97065, speed: 0.0, course: 344.0, accuracy: 4.9
2022-01-26 01:37:15 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:37:15 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:37:15 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:37:15, lat: 49.17580, lon: -122.97075, course: 90.0, accuracy: 14.0
2022-01-26 01:37:46 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:37:46 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:37:46 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:37:46, lat: 49.17580, lon: -122.97075, speed: 0.0, course: 190.0, accuracy: 4.9
2022-01-26 01:38:17 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:38:17 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:38:17 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:38:17, lat: 49.17580, lon: -122.97075, speed: 0.0, course: 190.0, accuracy: 4.9
2022-01-26 01:38:47 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:38:47 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:38:47 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:38:47, lat: 49.17580, lon: -122.97075, speed: 0.0, course: 190.0, accuracy: 4.9
2022-01-26 01:39:18 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:39:18 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:39:18 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:39:18, lat: 49.17580, lon: -122.97075, speed: 0.0, course: 190.0, accuracy: 4.9
2022-01-26 01:39:54 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:39:54 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:39:54 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:39:54, lat: 49.17580, lon: -122.97075, speed: 0.0, course: 190.0, accuracy: 4.9
2022-01-26 01:40:24 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:40:24 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:40:24 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:40:24, lat: 49.17580, lon: -122.97075, speed: 0.0, course: 190.0, accuracy: 4.9
2022-01-26 01:40:54 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 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
2022-01-26 01:40:54 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:40:54 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:40:54, lat: 49.17580, lon: -122.97075, speed: 0.0, course: 190.0, accuracy: 4.9
2022-01-26 01:41:25 INFO: [3d6276ac: osmand < 192.168.1.87] HEX: 504f5354202f3f69643d3134333833372674696d657374616d703d31363433313930303835266c61743d34392e31373536363831266c6f6e3d2d3132322e393730343736362673706565643d302e3030353238353937333933343735333739382662656172696e673d3330332e3939363138353330323733343426616c7469747564653d2d31332e39303030303035373232303435392661636375726163793d342e39303030303030393533363734333226626174743d372e3020485454502f312e310d0a436f6e74656e742d547970653a206170706c69636174696f6e2f782d7777772d666f726d2d75726c656e636f6465640d0a557365722d4167656e743a2044616c76696b2f322e312e3020284c696e75783b20553b20416e64726f69642031303b20564f472d4c3034204275696c642f485541574549564f472d4c3034290d0a486f73743a206272756e742e6475636b646e732e6f72673a353035350d0a436f6e6e656374696f6e3a204b6565702d416c6976650d0a4163636570742d456e636f64696e673a20677a69700d0a436f6e74656e742d4c656e6774683a20300d0a0d0a
2022-01-26 01:41:25 INFO: [3d6276ac: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 01:41:25 INFO: [3d6276ac] id: 143837, time: 2022-01-26 01:41:25, lat: 49.17567, lon: -122.97048, speed: 0.0, course: 304.0, accuracy: 4.9
2022-01-26 01:46:25 INFO: [3d6276ac] disconnected
2022-01-26 01:49:05 WARN: A servlet request to the URI http://backend/api/session?_dc=1643190546825 contains form parameters in the request body but the request body has been consumed by the servlet or a servlet filter accessing the request parameters. Only resource methods using @FormParam will work as expected. Resource methods consuming the request body by other means will not work as expected.
2022-01-26 02:00:52 INFO: [9e74f0d1] connected
2022-01-26 02:00:52 INFO: [9e74f0d1: osmand < 192.168.1.87] HEX: 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
2022-01-26 02:00:52 INFO: [9e74f0d1: osmand > 192.168.1.87] HEX: 485454502f312e3120323030204f4b0d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-01-26 02:00:53 INFO: [9e74f0d1] id: 143837, time: 2022-01-26 02:00:51, lat: 49.17569, lon: -122.97051, speed: 0.0, course: 290.7, accuracy: 7.7
2022-01-26 02:02:39 WARN: A servlet request to the URI http://backend/api/session?_dc=1643191360018 contains form parameters in the request body but the request body has been consumed by the servlet or a servlet filter accessing the request parameters. Only resource methods using @FormParam will work as expected. Resource methods consuming the request body by other means will not work as expected.
configuration.yaml:
device_tracker:
- platform: ping
hosts:
clarity_ping: 192.168.1.72
interval_seconds: 5
consider_home: 5
- platform: traccar
host: 127.0.0.1
port: 18682
username: <redacted>
password: <redacted>
ssl: true
event: ['all_events']
new_device_defaults:
track_new_devices: true
Help!!
