Hi!
Noob warning… I tried first install Hassbian and with that I get my z-wave working (Aeon Z-Stick S2). But with hass.io I cannot get it working… I’ve tried to find solution but with no luck ;). Raspberry 2.
Anybody could help?
Here is log:
2019-07-12 14:21:23.961 Always, OpenZwave Version 1.4.3440 Starting Up
2019-07-12 14:21:44.744 Info, Setting Up Provided Network Key for Secure Communications
2019-07-12 14:21:44.745 Info, mgr, Added driver for controller /dev/ttyAMA0
2019-07-12 14:21:44.745 Info, Opening controller /dev/ttyAMA0
2019-07-12 14:21:44.746 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2019-07-12 14:21:44.750 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2019-07-12 14:21:44.751 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-07-12 14:21:44.751 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-07-12 14:21:44.752 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-07-12 14:21:44.752 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-07-12 14:21:44.752 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-07-12 14:21:44.752 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-07-12 14:21:45.753 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-07-12 14:21:45.753 Detail, contrlr, Removing current message
2019-07-12 14:21:45.754 Detail, contrlr, Notification: Notification - TimeOut
2019-07-12 14:21:45.755 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-07-12 14:21:46.755 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-07-12 14:21:46.755 Detail, contrlr, Removing current message
2019-07-12 14:21:46.756 Detail, contrlr, Notification: Notification - TimeOut
2019-07-12 14:21:46.757 Detail,
2019-07-12 14:21:46.757 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-07-12 14:21:47.757 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-07-12 14:21:47.757 Detail, contrlr, Removing current message
2019-07-12 14:21:47.758 Detail, contrlr, Notification: Notification - TimeOut
2019-07-12 14:21:47.759 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-07-12 14:21:48.759 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-07-12 14:21:48.759 Detail, contrlr, Removing current message
2019-07-12 14:21:48.760 Detail, contrlr, Notification: Notification - TimeOut
2019-07-12 14:21:48.760 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-07-12 14:21:49.761 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-07-12 14:21:49.761 Detail, contrlr, Removing current message
2019-07-12 14:21:49.762 Detail, contrlr, Notification: Notification - TimeOut
