Something like this worked years ago, but is not working now. Any workaround? I can have multiple notifiers with different platforms, but not two for telegram
The docs for Telegram say that you can have two (or more) Telegram notifiers and they give the example as you have it written above. (I don’t use it so I can’t say whether it actually does or not)
if it’s not working per the docs then you might need to submit an issue for the integration.
