First time posting.
I’ve been running Home Assistant for long while without any issues. Tried to restart and get this message along with output from the log.
This appears to look serious. Any help and direction is appreciated.
Home Assistant 2023.5.2
Frontend 20230503.3 - latest
cannot import name ‘check_config’ from ‘homeassistant.helpers’ (/usr/src/homeassistant/homeassistant/helpers/init.py)
Home Assistant Core
Error while processing event EventTask(event=<Event state_changed[L]: entity_id=sensor.lumi_lumi_weather_0c76f806_temperature, old_state=<state sensor.lumi_lumi_weather_0c76f806_temperature=71.8; state_class=measurement, unit_of_measurement=°F, device_class=temperature, friendly_name=weather_sensor_upstairs_temperature @ 2023-05-10T14:26:28.204547-05:00>, new_state=<state sensor.lumi_lumi_weather_0c76f806_temperature=71.6; state_class=measurement, unit_of_measurement=°F, device_class=temperature, friendly_name=weather_sensor_upstairs_temperature @ 2023-05-10T14:35:41.380183-05:00>>):
2:35:47 PM – (ERROR) Recorder - message first occurred at May 8, 2023 at 4:12:11 AM and shows up 82122 times
Can’t read Supervisor data:
2:35:11 PM – (WARNING) Home Assistant Supervisor - message first occurred at May 8, 2023 at 12:11:51 AM and shows up 742 times
Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‘172.30.32.2’, 80)]
2:35:11 PM – (ERROR) Home Assistant Supervisor - message first occurred at May 8, 2023 at 12:09:03 AM and shows up 8910 times
Error while processing event StatisticsTask(start=datetime.datetime(2023, 5, 10, 19, 10, tzinfo=datetime.timezone.utc), fire_events=True): The database connection has not been established
2:35:10 PM – (ERROR) Recorder - message first occurred at May 8, 2023 at 4:15:10 AM and shows up 703 times
[546947520192] cannot import name ‘check_config’ from ‘homeassistant.helpers’ (/usr/src/homeassistant/homeassistant/helpers/init.py)
2:35:05 PM – (ERROR) Home Assistant WebSocket API - message first occurred at 6:04:08 AM and shows up 6 times
Failed to to call /backups -
2:35:03 PM – (ERROR) Home Assistant Supervisor - message first occurred at 6:03:42 AM and shows up 27 times
Client error on /backups request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‘172.30.32.2’, 80)]
Unhandled exception
2:34:48 PM – (ERROR) /usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py - message first occurred at 2:34:44 PM and shows up 14 times
Error doing job: Task exception was never retrieved
2:34:45 PM – (ERROR) helpers/storage.py - message first occurred at May 8, 2023 at 12:16:32 AM and shows up 298 times
alexaapi.get_dnd_state((<alexapy.alexalogin.AlexaLogin object at 0x7f93e22c20>,), {}): A connection error occured: An exception of type ClientConnectorError occurred. Arguments: (ConnectionKey(host=‘alexa.amazon.com’, port=443, is_ssl=True, ssl=<ssl.SSLContext object at 0x7f93d3a540>, proxy=None, proxy_auth=None, proxy_headers_hash=5148463654688221752), gaierror(-3, ‘Try again’))
2:34:03 PM – (WARNING) runner.py - message first occurred at May 8, 2023 at 12:13:22 AM and shows up 1460 times
Request exception for ‘https://api.github.com/rate_limit’ with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2:33:16 PM – (ERROR) HACS (custom integration) - message first occurred at 12:03:15 AM and shows up 88 times
Cannot connect because unable to refresh token:
2:28:13 PM – (WARNING) runner.py - message first occurred at May 9, 2023 at 9:22:58 AM and shows up 163 times
Error from stream worker: Error opening stream (ERRORTYPE_113, Host is unreachable) rtsp://:@10.0.187.202:554//h264Preview_01_main
2:21:37 PM – (ERROR) Stream - message first occurred at May 6, 2023 at 12:03:15 AM and shows up 282 times
Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error ‘ClientConnectorError’
2:19:30 PM – (ERROR) components/met/init.py - message first occurred at May 8, 2023 at 12:22:10 AM and shows up 65 times
2:06:56 PM – (ERROR) components/cloud/alexa_config.py - message first occurred at May 8, 2023 at 1:53:56 AM and shows up 214 times
Timeout fetching reolink.Back Yard.motion_states data
1:48:40 PM – (ERROR) Reolink IP camera (custom integration) - message first occurred at May 6, 2023 at 12:04:10 AM and shows up 243 times
Unable to find referenced devices f6e4ff24f957b258eb111988b52f573f or it is/they are currently not available
7:03:45 AM – (WARNING) helpers/service.py - message first occurred at May 6, 2023 at 6:43:41 AM and shows up 30 times
Client error on /refresh_updates request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‘172.30.32.2’, 80)]
6:12:31 AM – (ERROR) Home Assistant Supervisor
Unexpected exception importing platform custom_components.hacs.hardware
6:03:39 AM – (ERROR) loader.py - message first occurred at 6:03:39 AM and shows up 4 times
[547046995472] Error handling message: Unknown error (unknown_error) Craig Jackson from 127.0.0.1 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Home Assistant/2023.4 (io.robbie.HomeAssistant; build:2023.460; iPadOS 16.4.1) Mobile/HomeAssistant, like Safari)
6:03:03 AM – (ERROR) Home Assistant WebSocket API - message first occurred at May 8, 2023 at 6:21:14 PM and shows up 12 times
Error sending analytics to https://analytics-api.home-assistant.io/v1: ClientConnectorError(ConnectionKey(host=‘analytics-api.home-assistant.io’, port=443, is_ssl=True, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-8385430568389157614), gaierror(-3, ‘Try again’))
12:03:15 AM – (ERROR) Analytics - message first occurred at May 9, 2023 at 12:03:15 AM and shows up 2 times
May 9, 2023 at 10:16:56 PM – (ERROR) config_entries.py - message first occurred at May 8, 2023 at 7:56:59 PM and shows up 6 times
Cannot find integration samsungtv
Error loading integration: samsungtv
May 9, 2023 at 10:16:56 PM – (ERROR) loader.py - message first occurred at May 8, 2023 at 7:56:59 PM and shows up 6 times
Timeout fetching brother data
May 9, 2023 at 10:13:16 AM – (ERROR) Brother Printer - message first occurred at May 9, 2023 at 9:21:26 AM and shows up 2 times
LEAP session ended. Reconnecting…
May 9, 2023 at 9:21:54 AM – (WARNING) runner.py - message first occurred at May 9, 2023 at 2:42:10 AM and shows up 11 times
Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
May 9, 2023 at 9:21:53 AM – (ERROR) Internet Printing Protocol (IPP) - message first occurred at May 7, 2023 at 8:11:52 AM and shows up 12 times
Error from stream worker: Stream ended; no additional packets
May 9, 2023 at 9:21:41 AM – (ERROR) Stream - message first occurred at May 7, 2023 at 1:59:59 AM and shows up 6 times
May 9, 2023 at 9:21:40 AM – (ERROR) Stream - message first occurred at May 7, 2023 at 2:00:00 AM and shows up 6 times
Traceback (most recent call last): File “/config/custom_components/reolink_dev/binary_sensor.py”, line 130, in handle_event await self._base.api.get_all_motion_states() File “/usr/local/lib/python3.10/site-packages/reolink/camera_api.py”, line 608, in get_all_motion_states response = await self.send(body) File “/usr/local/lib/python3.10/site-packages/reolink/camera_api.py”, line 1723, in send raise ApiError( reolink.exceptions.ApiError: API returned HTTP status ERROR code 502/Bad Gateway
May 9, 2023 at 9:21:40 AM – (ERROR) Reolink IP camera (custom integration) - message first occurred at May 7, 2023 at 2:00:01 AM and shows up 3 times
Motion states could not be queried from API
Error fetching Garage Door Relay data: Error fetching data: DeviceConnectionError()
May 9, 2023 at 9:21:27 AM – (ERROR) Shelly
Error fetching 10.0.187.151 data: Unable to connect to the device: 10.0.187.151:
May 9, 2023 at 9:21:11 AM – (ERROR) TP-Link Kasa Smart
Can’t refresh cloud token:
May 9, 2023 at 8:40:38 AM – (ERROR) runner.py - message first occurred at May 8, 2023 at 12:40:36 AM and shows up 35 times
alexaapi.get_activities((<alexapy.alexalogin.AlexaLogin object at 0x7f93e22c20>, 10), {}): A connection error occured: An exception of type ClientConnectorError occurred. Arguments: (ConnectionKey(host=‘api.amazon.com’, port=443, is_ssl=True, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=5148463654688221752), gaierror(-3, ‘Try again’))
May 8, 2023 at 10:17:22 PM – (WARNING) Alexa Media Player (custom integration) - message first occurred at May 8, 2023 at 8:08:23 PM and shows up 18 times
Giving up _static_request(…) after 5 tries (alexapy.aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.amazon.com:443 ssl:default [Try again])
May 8, 2023 at 10:17:22 PM – (ERROR) Alexa Media Player (custom integration) - message first occurred at May 8, 2023 at 8:08:23 PM and shows up 9 times
[547105168672] Disconnected: Did not receive auth message within 10 seconds
May 8, 2023 at 1:01:39 PM – (WARNING) Home Assistant WebSocket API
Error while processing event PurgeTask(purge_before=datetime.datetime(2023, 4, 28, 9, 12, 0, 147639, tzinfo=datetime.timezone.utc), repack=False, apply_filter=False): [Errno 30] Read-only file system: ‘//config/home-assistant_v2.db’ → ‘//config/home-assistant_v2.db.corrupt.2023-05-08T09:12:04.556729+00:00’
May 8, 2023 at 4:12:04 AM – (ERROR) Recorder
The system will rename the corrupt database file //config/home-assistant_v2.db to //config/home-assistant_v2.db.corrupt.2023-05-08T09:12:04.556729+00:00 in order to allow startup to proceed
Unrecoverable sqlite3 database corruption detected: (sqlite3.OperationalError) disk I/O error [SQL: PRAGMA wal_checkpoint(TRUNCATE);] (Background on this error at: Error Messages — SQLAlchemy 2.0 Documentation)
Error requesting homeassistant_alerts data: Cannot connect to host alerts.home-assistant.io:443 ssl:default [Try again]
May 8, 2023 at 3:03:49 AM – (ERROR) Home Assistant Alerts
Error fetching met data: Update failed:
May 8, 2023 at 12:22:10 AM – (ERROR) Meteorologisk institutt (Met.no)
Giving up _static_request(…) after 5 tries (alexapy.aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host alexa.amazon.com:443 ssl:<ssl.SSLContext object at 0x7f93d3a540> [Try again])
May 8, 2023 at 12:13:27 AM – (ERROR) runner.py - message first occurred at May 8, 2023 at 12:13:22 AM and shows up 4 times
Error fetching alexa_media data: Error communicating with API:
May 8, 2023 at 12:13:22 AM – (ERROR) Alexa Media Player (custom integration)
Timeout sending report to Alexa for switch.sengled_livingroom_wall_lights
May 8, 2023 at 12:09:16 AM – (ERROR) Amazon Alexa - message first occurred at May 7, 2023 at 12:22:10 AM and shows up 2 times
Error fetching hassio data: Error on Supervisor API:
May 8, 2023 at 12:09:03 AM – (ERROR) Home Assistant Supervisor
Disconnected from MQTT server core-mosquitto:1883 (16)
May 8, 2023 at 12:08:54 AM – (WARNING) MQTT - message first occurred at May 8, 2023 at 12:08:54 AM and shows up 2 times
Host 10.0.187.246 error renewing the Reolink subscription
May 7, 2023 at 2:13:52 AM – (ERROR) Reolink IP camera (custom integration)
Subscription process ended with wrong HTTP status: 400: Bad Request
May 7, 2023 at 2:13:52 AM – (WARNING) Reolink IP camera (custom integration)
:0:0 Script error.
May 6, 2023 at 5:32:27 AM – (ERROR) components/system_log/init.py
