I am trying to install the ampli-panel-card (GitHub - madmicio/ampli-panel-card: panel card for av-receiver).
when I try to load from custom repositories I get the message “Repository ‘madmicio/ampli-panel-card’ exists in the store” But then I am lost because I cannot find it.
I restarted home assistant, but that did not help.
Thank you for quick response. I enabled the experiment talk features and was able to find the plugin in the hacs store.
According to the readme.md I should add some lines to the resources, but in :8123/config/lovelace/resources there is allready something added. Should I still modify the resources part ?
Can I use this plugin on my HA which it is a container???
I can see the card on my dashboard but I didn’t understand what do you I do with those files (see screenshot).
