Hello.
I am trying to install Hass.io on my Raspberry Pi Zero with the image. It fails every time and gives me these errors that just keeps repeating.
Jan 08 06:42:57 hassio start-resin-supervisor[1797]: 18-01-08 06:42:57 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
Jan 08 06:42:58 hassio start-resin-supervisor[1797]: 18-01-08 06:42:58 INFO (SyncWorker_2) [hassio.docker.interface] Clean homeassistant/raspberrypi-homeassistant docker application
Jan 08 06:42:59 hassio start-resin-supervisor[1797]: 18-01-08 06:42:59 ERROR (SyncWorker_2) [hassio.docker] Can't create container from homeassistant: 409 Client Error: Conflict ("Conflict. The container name "/homeassistant" is already in use by container "c3642c15991c80b528bf25b33666fa2038ba576b7495e6d46c08b474b357ed39". You have to remove (or rename) that container to be able to reuse that name.")
Does anyone have any ideas for what’s wrong?
