Cannot install on CM4 Lite
I have:
  • HA Yellow PoE (though powering with a mains lead)
  • CM4 Lite (8GB / Wireless)
  • WD Green 240GB
I’ve followed the steps here:
And made it as far as Step 10 of installing the SW.
The Yellow LED flashes, then comes on solid for a bit while the green LED goes bananas.
I’m now left with a solid red LED with the green one flashing intermittently (~1Hz).
I can see the installer has claimed an IP address with the router, so it had a network connection available.
As there’s no indication of how long this step is supposed to take, so I’ve left it in this state for a couple of days, before trying to disconnect and reboot.
Upon reboot I get a solid green & red LED, with no network presence.
Any ideas where I go from here?
Can you connect using the serial console?
https://yellow.home-assistant.io/guides/use-serial-console-windows/
The WD Green appears to be a SATA drive. The HA Yellow is only compatible with M.2 NVME drives.
D’oh!
/back to Amazon
Looks like this should do?
https://www.ebuyer.com/1286700
