Cannot integrate Smartthings after removal
My Smartthings integration failed. I removed it and now try to add it again. Unfortunately it fails on webhook validation step. The webhook it wants to use is invalid (when tried in Postman it returns 404) and it is different than one which I can see in Home Assistant Cloud settings under smarttthings name (this one is valid and returns 200). I am frustated - nothing works.
Yep!
Had the same problem. You have to delete the integration from the /config directory.
Delete “smartthings” from the /config/.storage/ directory to be specific.
You’ll need the SSH & Terminal integration to be able to perform this step.
You’ll then be able to start the Smartthings integration all over again.
Thanks - this is the solution.
