Cannot log in from Home Assistant Wear OS app
Just wanted to chime in to confirm that the culprit seems to be DNS.
Setup: Samsung Galaxy S20 (Android 13) + Samsung Galaxy Watch 4 (Wear OS 4)
I have a HA instance that is only accessible from the local network, running SSL under a domain hassio.mydomain.com that is resolved by the DNS present in the network (but not in the public Internet). I could not get the Wear OS app to connect to the instance unless I forced WiFi on the watch - with Bluetooth on it connected without an issue. The moment it got routed via the BT connection - no luck.
I’ve decided to run a small experiment - I’ve added an A record in the public DNS to resolve hassio.mydomain.com to my local IP address e.g. 192.168.1.10 (you don’t need to tell me that this is an anti-pattern) and to my surprise it worked. This means that when the watch tries to access the network over the BT link, it ignores the DNS settings of the network the phone is connected to and uses something hard-coded. Which is a privacy-invading anti-pattern, but there is little we can do about this.
Just as @ng175 mentioned, if your device has any setting related to “Private DNS” disable it - it will prevent your network’s DNS setup from working.
extended and working again for me.
i have the same setup, also behind CF, did you got this solved? iw sa working once before i migrated the externall stuff behind a CF tunnel
also behind CF?
No, gave up.
I am using the cloudflare addon, tried all combinations of wifi, bt on/off on both watch and phone, but never got anywhere sadly :frowning:
Which device? (Sounds like a weird question)
Phone, Watch, HA app on phone, HA app on watch, HA itself, Pihole, DNS on router. I did try looking but cant seem to find it, and dont know which device to do a deep dive…
I have the same problem with my Pixel5 and Samsung Watch 5Pro.
Can this be fixed?
Hi, I’ve got it working!!!
Turns out the same solution I found to fix casting also fixes it for my Galaxy Watch too.
:grinning:
