I am an HA newbie. I’m trying to set up the Wyze integration from HACS. When I try to enter the email, psw, key id and apikey, I get an error msg. Any thoughts what I could be doing wrong?
Thanks in Advance
Lancer824
p.s. here is the error log …
Logger: aiohttp.server
Source: /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py:421
First occurred: 2:43:29 PM (4 occurrences)
Last logged: 2:43:36 PM
Error handling request
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py”, line 452, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py”, line 543, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py”, line 114, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 85, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 100, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 28, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 80, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 233, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 31, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 149, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 63, in with_admin
return await func(self, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 177, in post
return await super().post(request, flow_id)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 320, in async_configure
result = await self._async_handle_step(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 416, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File “/config/custom_components/wyzeapi/config_flow.py”, line 61, in async_step_user
await self.client.login(
File “/usr/local/lib/python3.11/site-packages/wyzeapy/init.py”, line 89, in login
await self._auth_lib.get_token_with_username_password(
File “/usr/local/lib/python3.11/site-packages/wyzeapy/wyze_auth_lib.py”, line 138, in get_token_with_username_password
raise UnknownApiError(response_json)
wyzeapy.exceptions.UnknownApiError: {‘description’: ‘Invalid credentials, please check username, password, keyid or apikey’, ‘requestId’: ‘c75975bb-ebce-428d-9313-e8d9621348e5’, ‘errorCode’: 1000}
