I have successfully installed docker and created the container from homeassistant/home-assistant:latest image.
Once I access the UI I’m asked to create the user. so far so good.
AfterI get into the interface, if I disconnect, I’m no more able to login.
Don’t know if it’s the same problem, but I am having the same issue on a PI with HassIO. Tried trusted network auth and anything else I could find.Still no luck. Only way I can get back in is to delete files in .storage dir. Broker, NodeRED, Samba, and SSH still work. Just can’t log in.
