Cannot make scene activate on the basis of the current input select setting
All I want to do is to activate (in an automation) the scene indicated by the input select. Can you please help with the code? (I am getting an error about extra keys not allowed at @ data[‘data_template’])
Many thanks!
- id: MasterScenesDown2
  alias: Master Scene Down2
    platform: state
    entity_id: input_select.master_scene_select
    - service: scene.turn_on
        data_template:
          entity_id: "{ { states('input_select.master_scene_select') } }"
If the state of your input select is actually the entity_id of the scene (i.e. scene.your_scene) you can just use:
    platform: state
    - scene: "{{ states('input_select.master_scene_select') }}"
Many thanks! tried this and the visual studio editor says that string does not match the pattern of "^scene etc. Also the automation appears unavailable… :frowning: any ideas what I could be doing wrong? many thanks!
edit: this seems the error from the log:
Logger: homeassistant.config
Source: config.py:445
First occurred: September 2, 2021, 10:52:38 PM (7 occurrences)
Last logged: 1:22:59 AM
Invalid config for [automation]: expected dict for dictionary value @ data[‘action’][0][‘data_template’]. Got None. (See /config/configuration.yaml, line 1165).
Invalid config for [automation]: Entity ID {{ states(‘input_select.master_scene_select’) }} is an invalid entity ID for dictionary value @ data[‘action’][0][‘scene’]. Got None. (See /config/configuration.yaml, line 1165).
Invalid config for [automation]: Entity ID scene."{{ states(‘input_select.master_scene_select’) }}" is an invalid entity ID for dictionary value @ data[‘action’][0][‘scene’]. Got None. (See /config/configuration.yaml, line 1165).
2021-09-03 01:17:19 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: Entity ID scene."{{ states('input_select.master_scene_select') }}" is an invalid entity ID for dictionary value @ data['action'][0]['scene']. Got None. (See /config/configuration.yaml, line 1165).
I don’t know why the shortcut version isn’t working in that specific case… probably something to do with “limited templates”.
I have checked the following, and it works on my system:
alias: ztest scene select w shortcut
  platform: state
      entity_id: "{{states('input_select.master_scene_select')}}"
mode: single
Thank you so much! it worked! :slight_smile: :slight_smile:
Code for anybody interested:
config.yaml
input_select:
  master_scene_select:
    options:
      - "scene.playroom_day"
      - "scene.playroom_night"
      - "scene.playroom_low"
      - "scene.playroom_ultra_low"
      - "scene.playroom_sleep"
      - "scene.playroom_off"
    initial: "scene.playroom_night"
automations.yaml
(you need 2 automations for each button - below code just for the down button)
- id: '1630606723125'
  alias: Master bedroom scene down triger
  description: ''
  - platform: state
    entity_id: binary_sensor.master_bedroom_scene_down
    to: 'on'
  condition: []
  - service: input_select.select_next
  mode: single
  - platform: state
      entity_id: '{{states(''input_select.master_scene_select'')}}'
  mode: single
If I understand what you are trying to do, you should be able combine your ‘up’ and ‘down’ automations into one automation using the “choose” action.
alias: Master bedroom scene combined
description: ''
  - platform: state
    entity_id: binary_sensor.master_bedroom_scene_up
    to: 'on'
  - platform: state
    to: 'on'
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: input_select.select_previous
      - conditions:
        sequence:
    default: []
mode: single
There is no reason to have a ‘MasterScenesDown2’ and a ‘MasterScenesUp2’… they would both be doing the exact same thing. You really only need 2 automations total, not 2 per button.
