Cannot migrate Plant sensors HHCCJCY01 from Passive BLE Monitor to Xiaomi BLE
I have recently added a few new HHCCJCY01 Plants sensors which showed up on the Xiaomi BLE integration. The problem I have is the existing HHCCJCY01 Plant sensors I already have in the system and were accessed using the Passive BLE monitor integration will not show up in the Xiaomi BLE integration. All of the Plant sensors are using firmware 3.3.5.
I have tried deleting the sensors from the Passive BLE Monitor.
I checked the core.device_registry and the entries have moved to the deleted devices list and are indicted as orphaned.
I have deleted these entries, restarted, reloaded, rebooted HA. the devices still will not be discovered by the Xiaomi BLE integration.
The Passive BLE Monitor picks them up straight away when I re-add them so they are visible to the system.
How do I reset/delete these devices in Home Assistant to be picked up by the Xiaomi BLE integration?
Solved by following instructions here, 3 steps.
Then removing the Devices from the core.device_registry. Reboot, and now can discover device on Xiaomi BLE
