Hi guys. I hope someone can help!
I am running the latest version of HA installed using the (now obsolete) supervised method, which I know it is not officially supported.
I am having troubles to open any web UI of any integrations. I am debugging the simple “File editor” just to test it out, and in the log I get this:
INFO:2020-10-24 18:14:11,424:hass_configurator.configurator:Starting server
INFO:2020-10-24 18:14:11,425:hass_configurator.configurator:Listening on: http://0.0.0.0:8099
WARNING:2020-10-24 18:18:04,279:hass_configurator.configurator:Client IP not within allowed networks.
INFO:2020-10-24 18:18:04,280:hass_configurator.configurator:172.30.32.1 - "GET / HTTP/1.1" 420 -
I tried adding in the configruation.yaml under the http section, the line ip_ban_enabled:false but it didn’t fix the issue. I am wondering if I should enable any port forwarding? But I am sure exactly what to do.
Thanks in advance!
