I’ve been trying to connect the CC2531 dongle to Home Assistant. The USB device is detected. But when I start the addon, it won’t be able to connect to it. Here are the logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[12:38:43] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[12:38:45] INFO: MQTT available, fetching server detail ...
[12:38:45] INFO: Previous config file found, checking backup
[12:38:45] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[12:38:45] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[12:38:46] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start /app
> node index.js
Zigbee2MQTT:error 2021-07-15 12:38:51: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-07-15 12:38:51: Failed to start zigbee
Zigbee2MQTT:error 2021-07-15 12:38:51: Exiting...
Zigbee2MQTT:error 2021-07-15 12:38:51: Error: Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/bus/usb/002/004'
at Znp.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
at Generator.next (<anonymous>)
at /app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
at new Promise (<anonymous>)
at __awaiter (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
at SerialPort.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
at SerialPort._error (/app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
at /app/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2021-07-15T10_38_51_158Z-debug.log
[12:38:51] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
This is -part of- the output of the command ha hardware info
- attributes:
BUSNUM: "002"
DEVNAME: /dev/bus/usb/002/004
DEVNUM: "004"
DEVPATH: /devices/pci0000:00/0000:00:06.0/usb2/2-2
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-pci-0000_00_06_0-usb-0_2
ID_MODEL: CC2531_USB_Dongle
ID_MODEL_ENC: CC2531\x20USB\x20Dongle
ID_MODEL_ID: 16ae
ID_PATH: pci-0000:00:06.0-usb-0:2
ID_PATH_TAG: pci-0000_00_06_0-usb-0_2
ID_REVISION: "6296"
ID_SERIAL: Texas_Instruments_CC2531_USB_Dongle
ID_USB_INTERFACES: ':ffffff:'
ID_VENDOR: Texas_Instruments
ID_VENDOR_ENC: Texas\x20Instruments
ID_VENDOR_ID: "0451"
MAJOR: "189"
MINOR: "131"
PRODUCT: 451/16ae/6296
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 0/0/0
USEC_INITIALIZED: "506160837778"
by_id: null
dev_path: /dev/bus/usb/002/004
subsystem: usb
sysfs: /sys/devices/pci0000:00/0000:00:06.0/usb2/2-2
And this is the config of the addon itself:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://182.168.178.35:1883
user: user
password: pass
serial:
port: /dev/bus/usb/002/004
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
In the
serial:
I’ve tried /sys/devices/pci0000:00/0000:00:06.0/usb2/2-2
and /devices/pci0000:00/0000:00:06.0/usb2/2-2
without much luck. Am I missing something? Or do I have to do an extra step to the dongle? I just received it and plugged it in.
