Cannot pair an Ikea MYGGSPRAY motion sensor and GRILLPLATS smart plug
I have HA with Z2M, everything works fine. I added an SLZB-06MU running in “Thread+OTBR running on device (experimental)” mode. Everything seems okay.
I wanted to add some Matter devices but it just doesn’t work. I (think) I tried everything.
  • I checked IPv6 support (Crucial for Matter) = OK
  • The SLZB-06MU is using my HomePod Mini’s preferred Thread network.
  • I tried resetting the MYGGSPRAY, scan the QR code, enter the pairing code, took out the batteries, I tried everything, nothing seems to work.
Am I missing something?
Edit: my HA is on a Proxmox VM.
Copying the thread credentials from HA to the phone.
The one copy function that is easy to find in HA for Matter is copying from the phone to HA and since the thread credentials on the phone is wrong then it will all be wrong.
It is a bit tricky to find the right one, because you need to be on the phone and in the companion app.
When there you need to go to the settings and the select the companion app section.
Now find troubleshooting (look from the bottom and up) and in there find the sync thread credentials.
Thank you @WallyR but that’s not it. The SLZB-06MU is configured correctly and uses the same TLV as the HomePod Mini. All good there.
Yeah, but your phone needs to use it too.
Found it myself with the help of my best friend Claude. The fix was one setting on the Proxmox host, so posting in case it saves someone the same hunt.
Setup: HAOS in a Proxmox VM (vmbr0 bridge), Zigbee via Z2M on an SLZB-06M and another SLZB-06MU, which runs Thread+OTBR on-device (experimental). HomePod Mini as a second Thread border router, both on one Thread network. Commissioning Matter devices (IKEA MYGGSPRAY) from the HA iOS app.
Symptom: Pairing starts, spins for a while, then fails with a generic “unable to add.” Device side was fine; reset, QR, pairing code, battery pull, nothing changed it. IPv6 was enabled, the Thread network showed both border routers, device and controller were on the same network. Everything looked right.
The cause: The Linux bridge was dropping IPv6 multicast. Matter’s operational discovery runs over mDNS/multicast, so the device would join Thread but HA could never find it afterward, hence the long wait then failure. On the bridge, multicast snooping was on with no querier:
cat /sys/class/net/vmbr0/bridge/multicast_snooping   # 1
cat /sys/class/net/vmbr0/bridge/multicast_querier    # 0
Snooping on + no querier = group memberships get pruned and nothing re-learns them, so multicast to the VM dies silently. The VM can have a perfectly good IPv6 address and still fail.
The fix. Test it live first (because reverts on reboot):
echo 0 > /sys/class/net/vmbr0/bridge/multicast_snooping
Retried the pairing and it worked immediately. Make it persistent by adding this line to the iface vmbr0 stanza in /etc/network/interfaces on the Proxmox host:
bridge-mcsnoop 0
Then ifreload -a and confirm it reads 0. Use your real bridge name if it isn’t vmbr0. Heads-up: editing the bridge in the Proxmox web UI later can rewrite this file, so re-check the line if you do.
Two gotchas along the way:
  • After the fix, the iPhone threw “Thread network credentials does not match any of the active thread networks around.” That’s actually a good sign (the phone can suddenly see Thread networks to compare). It was a stale credential from me deleting an old leftover Thread network mid-process. Fix: force-quit the HA app, open Apple Home once to refresh iOS’s Thread store, confirm your main network is still set as preferred with its border routers in HA’s Thread panel, retry. After that you can just tap “Continue” past it and add the device.
  • “IPv6 is fine” usually means the WAN/router. Matter discovery runs over link-local/ULA + mDNS on the local segment, not your global address — so a healthy IPv6 address tells you nothing about whether multicast reaches the VM. That’s the part to actually verify.
TL;DR: Matter commissioning fails on a bridged Proxmox VM → multicast_snooping is 1 with multicast_querier 0 → set bridge-mcsnoop 0 on the bridge → done.
