I installed on new Raspberry 4b clean version of HA following instructions from documentationi HA is working with no problems, but I try to connect some zigbee sensors to it so (ex. Mi light detection sensor GZCGQ01LM from what i found it should be supported Xiaomi Mi Light Detection Sensor (GZCGQ01LM) Zigbee compatibility).
To connect i use conbee 2 dongle with latest firmware (dongle is working on windows machine in DeCONZ with this sensor)
I installed zigbee2mqtt like in instruction https://hejdom.pl/blog/22-home-assistant/332-home-assistant-zigbee2mqtt-conbee-konfiguracja.html and have configurations:
Zigbee2mqtt
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
serial:
port: /dev/ttyACM0
adapter: deconz
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
xxxxxxx
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
Mosquitto broker
certfile: fullchain.pem
customize:
active: false
folder: mosquitto
keyfile: privkey.pem
logins: []
require_certificate: false
webui zigbee2mqtt is working and when i try to pair device i got timer and device is not foud (device in paring mode)
logs are clean
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[16:12:14] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[16:12:14] INFO: Starting NGINX for authentication handling...
[16:12:15] INFO: Starting mosquitto MQTT broker...
1642173135: mosquitto version 1.6.12 starting
1642173135: |-- *** auth-plug: startup
[16:12:16] INFO: Successfully send discovery information to Home Assistant.
[16:12:16] INFO: Successfully send service information to the Supervisor.
1642173135: Config loaded from /etc/mosquitto/mosquitto.conf.
1642173135: Loading plugin: /usr/share/mosquitto/auth-plug.so
1642173135: ├── Username/password checking enabled.
1642173135: ├── TLS-PSK checking enabled.
1642173135: └── Extended authentication not enabled.
1642173135: Opening ipv4 listen socket on port 1883.
1642173135: Opening ipv6 listen socket on port 1883.
1642173135: Opening websockets listen socket on port 1884.
1642173135: Warning: Mosquitto should not be run as root/administrator.
1642173135: mosquitto version 1.6.12 running
1642173135: New connection from 127.0.0.1 on port 1883.
1642173135: Socket error on client <unknown>, disconnecting.
1642173146: New connection from 172.30.32.1 on port 1883.
1642173146: New client connected from 172.30.32.1 as auto-C3C997A4-39C6-DC01-A12B-72C3EBE414BB (p2, c1, k60, u'homeassistant').
1642173146: Client auto-C3C997A4-39C6-DC01-A12B-72C3EBE414BB disconnected.
1642173146: New client connected from 172.30.32.1 as 4r3w4IoKfzht4x9802wkXO (p2, c1, k60, u'homeassistant').
1642173379: New connection from 172.30.33.1 on port 1883.
1642173379: New client connected from 172.30.33.1 as mqttjs_bc186a6b (p2, c1, k60, u'addons').
1642174936: Saving in-memory database to /data/mosquitto.db.
1642175311: Client mqttjs_bc186a6b disconnected.
1642175324: New connection from 172.30.33.1 on port 1883.
1642175324: New client connected from 172.30.33.1 as mqttjs_85e34efe (p2, c1, k60, u'homeassistant').
1642175472: Client mqttjs_85e34efe disconnected.
1642175486: New connection from 172.30.33.1 on port 1883.
1642175486: New client connected from 172.30.33.1 as mqttjs_6e1474d6 (p2, c1, k60, u'addons').
1642175506: New connection from 172.30.32.1 on port 1883.
1642175506: New client connected from 172.30.32.1 as 6lDr4FEtQSz4fF3IHVNK4I (p1, c1, k60, u'homeassistant').
1642175506: Client 6lDr4FEtQSz4fF3IHVNK4I disconnected.
1642175528: Socket error on client 4r3w4IoKfzht4x9802wkXO, disconnecting.
1642175528: New connection from 172.30.32.1 on port 1883.
[fix-attrs.d] done.
[cont-init.d] socat.sh: executing...
[16:51:15] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[16:51:16] INFO: MQTT available, fetching server detail ...
[16:51:16] INFO: MQTT server settings not configured, trying to auto-discovering ...
[16:51:17] INFO: Configuring 'mqtt://core-mosquitto:1883' mqtt server
[16:51:17] INFO: MQTT credentials not configured, trying to auto-discovering ...
[16:51:17] INFO: Configuring'addons' mqtt user
[16:51:17] INFO: Previous config file found, checking backup
[16:51:17] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[16:51:18] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] done.
[16:51:19] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
CREATED DECONZ ADAPTER
