th3gam3
(Th3gam3)
1
I plan to publish state of the switch from HA to the LCD Display. But the display always shows off even i turn on the pump.
Pls help
The config looks like this:
binary_sensor:
- platform: homeassistant
entity_id: switch.water_pump
i2c:
sda: D2
scl: D1
display:
- platform: lcd_pcf8574
dimensions: 16x2
address: 0x27
update_interval: 1s
lambda: |-
it.printf("My State: %s", id(water_pump).state ? "on" : "off");
nickrout
(Nick Rout)
2
Can you show us your Log?
th3gam3
(Th3gam3)
3
[13:27:42][I][app:106]: ESPHome version 2021.8.2 compiled on Sep 7 2021, 13:26:47
[13:27:42][C][wifi:499]: WiFi:
[13:27:42][C][wifi:359]: SSID: [redacted]
[13:27:42][C][wifi:360]: IP Address: 192.168.1.96
[13:27:42][C][wifi:362]: BSSID: [redacted]
[13:27:42][C][wifi:363]: Hostname: 'irrigation-alfa-control'
[13:27:42][C][wifi:367]: Signal strength: -52 dB ▂▄▆█
[13:27:42][C][wifi:371]: Channel: 1
[13:27:42][C][wifi:372]: Subnet: 255.255.255.0
[13:27:42][C][wifi:373]: Gateway: 192.168.1.1
[13:27:42][C][wifi:374]: DNS1: (IP unset)
[13:27:42][C][wifi:375]: DNS2: (IP unset)
[13:27:42][C][i2c:028]: I2C Bus:
[13:27:42][C][i2c:029]: SDA Pin: GPIO4
[13:27:42][C][i2c:030]: SCL Pin: GPIO5
[13:27:42][C][i2c:031]: Frequency: 50000 Hz
[13:27:42][I][i2c:033]: Scanning i2c bus for active devices...
[13:27:42][I][i2c:040]: Found i2c device at address 0x27
[13:27:42][C][logger:189]: Logger:
[13:27:42][C][logger:190]: Level: DEBUG
[13:27:42][C][logger:191]: Log Baud Rate: 115200
[13:27:42][C][logger:192]: Hardware UART: UART0
[13:27:42][C][homeassistant.time:010]: Home Assistant Time:
[13:27:42][C][homeassistant.time:011]: Timezone: 'TZ-8'
[13:27:42][C][lcd_pcf8574:023]: PCF8574 LCD Display:
[13:27:42][C][lcd_pcf8574:024]: Columns: 16, Rows: 2
[13:27:42][C][lcd_pcf8574:025]: Address: 0x27
[13:27:42][C][lcd_pcf8574:026]: Update Interval: 1.0s
[13:27:42][C][captive_portal:148]: Captive Portal:
[13:27:42][C][web_server:152]: Web Server:
[13:27:42][C][web_server:153]: Address: 192.168.1.96:80
[13:27:42][C][ota:029]: Over-The-Air Updates:
[13:27:42][C][ota:030]: Address: 192.168.1.96:8266
[13:27:42][C][ota:032]: Using Password.
[13:27:42][C][api:095]: API Server:
[13:27:42][C][api:096]: Address: 192.168.1.96:6053
[13:27:42][C][homeassistant.binary_sensor:038]: Homeassistant Binary Sensor 'water_pump'
[13:27:42][C][homeassistant.binary_sensor:039]: Entity ID: 'switch.water_pump'
also i have defined in HA the switch.
nickrout
(Nick Rout)
4
What do you see in the esphome log when switch.water_pump
goes to on?
th3gam3
(Th3gam3)
5
nothing got updated in the esphome log when switch.water_pump
goes to on.
The last entry
th3gam3
(Th3gam3)
6
Well looks like i solve this by manually adding the ESPHOME node manually instead of auto discovery and added by HA.
That solved the prob. now everything works!
