I have two Aqara P1 motion sensors also known as lumi.sensor_motion.aq2.
I added both via ZHA and they worked fine at first. Then one of them dropped off the network, so I went through removing the device and attempting to re-add it.
This doesn’t work: the device is always registered with inaccessible entities and it doesn’t actually work any more. I’ve tried it many times.
If I inspect any of its entities, the warning This entity is unavailable
is displayed.
In the logs, I noticed this line:
<timestamp> DEBUG (MainThread) [zigpy.appdb] Error handling '_save_attribute' event with (<IEEE redacted>, 1, 0, 5, 'lumi.sensor_motion.aq2', datetime.datetime(...)) params: FOREIGN KEY constraint failed
Has my Zigbee database become messed up?
How do I repair this?
