Dear all,
I’m running HA as VM on a Synology Diskstation.
Used to access the frontend internally using http (http:// IP:8123) and externally using my own domain with installed certificats on the Diskstation by using its reverse proxy (https:// MY.DOMAIN with reverse proxy https:// MY.DOMAIN:443->http:// IP:8123). This worked well with the LetsEncrypt Certificates from my Diskstation.
Tonight I had the stupid idea to setup https for internal access as well and added the following lines to configuration.yaml after creating the folder “ssl” within config and uploading the two certificate file exported from my diskstation:
http:
ssl_certificate: /config/ssl/fullchain.pem
ssl_key: /config/ssl/privkey.pem
After restarting HA, its no more possible to reach the fronted using http://IP:8123 or https://IP:8123 internally. Likewise, external access to frontend is no more working.
I cannot edit configuration.yaml using SSH since the add-on is not installed.
Oberver ist working (http:// IP:4357):
|Supervisor:|Connected|
|Supported:|Supported|
|Healthy:|Healthy|
Do you see any chance to access configuration.yaml, remove the three lines mentioned above and restart?
Any help is highly appreciated, I crashed a well working system and put many hours and efforts to it.
All the best and kind regards
Mngsps
(added the spaces after http/https since i was not allowed to post more than 2 links)
