Starting this morning I cannot reach my Yellow via the local network, since it operated about half a year flawlessly (except my wrong device configurations… ). I never touch the OS files except the regular updates.
I also never accessed the device via PuTTY until now. So I’m pretty sure I did not mess up the files.
When I read the log files during boot correctly it seems that the network manager does not start as it should. The result is that the Yellow does not have an IP-Address and therefore can’t be reached.
No ping answer from outside to the yellow and a ping from the yellow to the gateway is also not answered.
Network Info:
ha network info
docker:
address: 172.30.32.0/23
dns: 172.30.32.3
gateway: 172.30.32.1
interface: hassio
host_internet: false
interfaces:
- connected: true
enabled: true
interface: end0
ipv4:
address:
gateway: null
method: auto
nameservers:
ready: false
ipv6:
address:
gateway: null
method: auto
nameservers:
ready: false
mac: E4:5F:01:F7:17:0B
primary: false
type: ethernet
vlan: null
wifi: null
supervisor_internet: false
Part of the Boot sequence:
[ OK ] Started Hostname Service.
Starting Network Manager Script Dispatcher Service...
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting Network Manager Wait Online...
Starting containerd container runtime...
Starting HassOS Configuration Manager...
Starting Permit User Sessions...
[ OK ] Finished Permit User Sessions.
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Finished HassOS Configuration Manager.
[ OK ] Started containerd container runtime.
[ 10.975452] Bluetooth: hci0: command 0xfc18 tx timeout
[ 10.980683] Bluetooth: hci0: BCM: Reset failed (-110)
[ OK ] Stopped target Bluetooth Support.
[ OK ] Started Remove HCI kernel driver iFi/Bluetooth module is not present.
[ OK ] Reached target HassOS hardware targets.
[* ] A start job is running for Network Manager Wait Online (9s / no limit)
[** ] A start job is running for Network nager Wait Online (10s / no limit)
…continues counting the seconds…
[ **] A start job is running for Network r Wait Online (1min 1s / no limit)
[ ***] A start job is running for Network r Wait Online (1min 1s / no limit)
[ *** ] A start job is running for Network r Wait Online (1min 2s / no limit)
[*** ] A start job is running for Network r Wait Online (1min 3s / no limit)
[** ] A start job is running for Network r Wait Online (1min 3s / no limit)
[* ] A start job is running for Network r Wait Online (1min 4s / no limit)
[** ] A start job is running for Network r Wait Online (1min 4s / no limit)
[*** ] A start job is running for Network r Wait Online (1min 5s / no limit)
[ *** ] A start job is running for Network r Wait Online (1min 5s / no limit)
[ *** ] A start job is running for Network r Wait Online (1min 6s / no limit)
[FAILED] Failed to start Network Manager Wait Online.
See ‘systemctl status NetworkManager-wait-online.service’ for details.
[ OK ] Reached target Network is Online.
Starting Notify NFS peers of a restart...
Starting Wait Until Kernel Time Synchronized...
Starting Network Time Synchronization...
[ OK ] Started Notify NFS peers of a restart.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ ***] A start job is running for Wait Unt Synchronized (1min 8s / 2min 36s)
[ **] A start job is running for Wait Unt Synchronized (1min 9s / 2min 36s)
[ *] A start job is running for Wait Unt Synchronized (1min 9s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 10s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 10s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 11s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 12s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 12s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (1min 13s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 13s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 14s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 14s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 15s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 15s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 16s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (1min 16s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 17s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 17s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 18s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 19s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 19s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (1min 20s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 20s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 21s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 21s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 22s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 22s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 23s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (1min 23s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 24s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 24s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 25s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 26s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 26s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (1min 27s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 27s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 28s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 28s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 29s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 29s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 30s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (1min 30s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 31s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 31s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 32s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 33s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 33s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (1min 34s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 34s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 35s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 35s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 36s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 36s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 37s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (1min 37s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 38s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 38s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 39s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 40s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 42s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (1min 43s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 43s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 44s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 44s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 45s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 45s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 46s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (1min 46s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 47s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 47s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 48s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 49s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 49s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (1min 50s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 50s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 51s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 51s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 52s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 52s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 52s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (1min 53s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 53s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 54s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 54s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 55s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 55s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 56s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (1min 56s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (1min 57s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (1min 57s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (1min 58s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (1min 59s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (1min 59s / 2min 36s)
[ *] A start job is running for Wait Untime Synchronized (2min / 2min 36s)
[ **] A start job is running for Wait Untime Synchronized (2min / 2min 36s)
[ ***] A start job is running for Wait Unt Synchronized (2min 1s / 2min 36s)
[ *** ] A start job is running for Wait Unt Synchronized (2min 1s / 2min 36s)
[ *** ] A start job is running for Wait Unt Synchronized (2min 2s / 2min 36s)
[*** ] A start job is running for Wait Unt Synchronized (2min 2s / 2min 36s)
[** ] A start job is running for Wait Unt Synchronized (2min 3s / 2min 36s)
[* ] A start job is running for Wait Unt Synchronized (2min 3s / 2min 36s)
[** ] A start job is running for Wait Unt Synchronized (2min 4s / 2min 36s)
[*** ] A start job is running for Wait Unt Synchronized (2min 4s / 2min 36s)
[ *** ] A start job is running for Wait Unt Synchronized (2min 5s / 2min 36s)
[ ***] A start job is running for Wait Unt Synchronized (2min 6s / 2min 36s)
[ **] A start job is running for Wait Unt Synchronized (2min 6s / 2min 36s)
[ *] A start job is running for Wait Unt Synchronized (2min 7s / 2min 36s)
[ **] A start job is running for Wait Unt Synchronized (2min 7s / 2min 36s)
[ ***] A start job is running for Wait Unt Synchronized (2min 8s / 2min 36s)
[ *** ] A start job is running for Wait Unt Synchronized (2min 8s / 2min 36s)
[ *** ] A start job is running for Wait Unt Synchronized (2min 9s / 2min 36s)
[*** ] A start job is running for Wait Unt Synchronized (2min 9s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (2min 10s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (2min 10s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (2min 11s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (2min 11s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 12s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (2min 13s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (2min 13s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (2min 14s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (2min 14s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (2min 15s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 15s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 16s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (2min 16s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (2min 17s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (2min 17s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (2min 18s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (2min 18s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 19s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (2min 20s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (2min 20s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (2min 21s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (2min 21s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (2min 22s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 22s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 23s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (2min 23s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (2min 24s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (2min 24s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (2min 25s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (2min 27s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 28s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (2min 29s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (2min 29s / 2min 36s)
[ *] A start job is running for Wait UntSynchronized (2min 30s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (2min 30s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (2min 31s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 31s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 32s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (2min 32s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (2min 33s / 2min 36s)
[* ] A start job is running for Wait UntSynchronized (2min 33s / 2min 36s)
[** ] A start job is running for Wait UntSynchronized (2min 34s / 2min 36s)
[*** ] A start job is running for Wait UntSynchronized (2min 34s / 2min 36s)
[ *** ] A start job is running for Wait UntSynchronized (2min 35s / 2min 36s)
[ ***] A start job is running for Wait UntSynchronized (2min 36s / 2min 36s)
[ **] A start job is running for Wait UntSynchronized (2min 36s / 2min 36s)
[FAILED] Failed to start Wait Until Kernel Time Synchronized.
See ‘systemctl status systemd-time-wait-sync.service’ for details.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Discard unused filesystem blocks once a week.
[ OK ] Reached target Timer Units.
Starting HassOS AppArmor...
[ OK ] Finished HassOS AppArmor.
Starting Docker Application Container Engine...
[ *] A start job is running for Docker Aainer Engine (2min 39s / no limit)
[ **] A start job is running for Docker Aainer Engine (2min 39s / no limit)
[ OK ] Started libcontainer container 0d3042c68e1a93b117bc2118a6d7ca4d29583.
[ OK ] Started Docker Application Container Engine.
Starting HassOS supervisor...
What can I do?
