I had the same isue, i solved with changing SQllite( the default database) with MySQL and now everything is working like a charm
I guess I will check into this. I have stayed away as many seem to have had difficulties in switching.
It’s not so hard to do it and the benefits are alot
1.http://www.raspberry-projects.com/pi/software_utilities/web-servers/mysql
2.https://home-assistant.io/components/recorder/
…and thas it
Thanks, I will check it out. Do you think the steps are the same for a non-raspberry? I run Ubuntu 16.04 on a G6 server.
It shoud be, but why are you running on so powerful mashine?
Came across it very cheaply. I use it to run ZoneMinder with 10 cameras as well. Still waiting to see if there is anything else to add to it. If I don’t find anything I may step down to just a dedicated PC/laptop.
I am getting this same error message in a couple of my motion sensors.
Same error since 0.50
I´m having the same issue here, on version 0.50.2.
I´ve noticed it only happens when I try to use Owntracks and GPSLogger, Router device_tracker works fine.
Cheers
Hello everyone!
I am quite new at everything here (rpi,linux,homeassistant), but learning fast…
I have the same issue (cannot read property ‘v’ of undefined). Now i have updated to 0.51.2 and it is the same. It appears at the states, which are not changing states for some time. For example i have some binary statuses from my PLC (via modbus TCP) that are the same for some time (example: PLC_battery_OK)…
I am running RPi 3 with hassbian on it.
Best regards,
Blaz
