I am running Home Assistant core in Docker
Today I wanted to add "vertical-stack-in-card " to hacs
Something went wrong apparently because HACS disappeared from the sidebar.
So I removed and reinstalled it following the instructions.
However it does not show in the sidebar.
Besides that in the folder .storage there are no hacs files
Did you delete the integration and re-add it? Found at Configuration/Integrations. If there is a HACS item displayed, use the menu in the lower right corner of the box to delete it. Then the plus in the lower right corner of the screen to re-add it.
So it was not smart to upgrade HACS when running on 0109.2 ?
Then I think an option to upgrade should not be possible. I will try to restore from a previous installation.
EDIT : Release notes say : 0.110.0 is now the minimum required version of Home Assistant needed to run HACS. My fault
Would be nice to have this warning earlier.
