Hello all,
I recently bought some GoControl door sensors and I’ve been having trouble getting one paired with HomeAssistant and my Aoetec Z-Stick. The pairing process works great, but then when I put the cover back on the sensor, it just goes to sleep forever on the network and the device led just blinks (like it went back into pairing mode). Due to this problem, I’ve tried to remove and add the device multiple times, so now I have about 5 unwanted nodes showing up in my zwave list, all referencing the same device.
I’ve gone through the steps to forcefully remove them from the network, (setting is_failed=true and using “remove failed node”), but the removal always fails. I’ve tried restarting the zwave network, healing the network, restarting the host system, all to no avail. Any help would be greatly appreciated. Here is the relevant log entries I get when trying to remove the node.
2018-11-20 06:25:51.661 Detail, Node032, Queuing (Controller) Remove Failed Node
2018-11-20 06:25:51.661 Info, ControllerCommand_RemoveFailedNode
2018-11-20 06:25:51.661 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveFailedNode:
0x01, 0x05, 0x00, 0x61, 0x20, 0x8d, 0x36
2018-11-20 06:25:51.661 Detail, Notification: ControllerCommand - Starting
2018-11-20 06:25:51.662 Detail,
2018-11-20 06:25:51.662 Info, contrlr, Sending (Command) message (Callback ID=0x8d, Expected
Reply=0x61) - ControllerCommand_RemoveFailedNode: 0x01, 0x05, 0x00, 0x61, 0x20, 0x8d, 0x36
2018-11-20 06:25:51.663 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x61, 0x08, 0x93
2018-11-20 06:25:51.663 Warning, contrlr, WARNING: Received reply to
FUNC_ID_ZW_REMOVE_FAILED_NODE_ID - Node not found
2018-11-20 06:25:51.663 Detail, Node147, Expected callbackId was received
2018-11-20 06:25:51.663 Detail, Node147, Message transaction complete
2018-11-20 06:25:51.663 Detail, contrlr, Removing current message
2018-11-20 06:25:51.663 Detail, Notification: ControllerCommand - Failed
