Cannot rename Zwave entity, friendly_name not null
I previously factory reset zwave controller and all devices and repaired with HA
I recently realized that many devices have retained prior friendly_name. This means, HA default for friendly_name(greyed out) is “bedroom” instead of null. This name shows in frontend.
If I change frienfky_name it has no affect. So friendly_name defined as “kitchen” but frontend still show"bedroom"
I look in device_registry and entity_registry and friendly_name show null. I check other files and do not find any name defined.
Any suggestions?
If you reset your stick, did you delete the zwcfg_####.xml file? If not, it may still have cached data for names that its sending over to Home Assistant. Otherwise, check customize.yaml and see if anything is entered there.
No. XML file was not deleted but after reset file name is change so.the old file I expect not relevant. Also, this file hold zwave info not entity name info I thought?
Customize.yaml had nothing. I check this previously. Actually I check every file for something that may affect this and find nothing
