Hello all,
unfortunately I have a small problem and can not cope with the error analysis
I can not restart since today, it always gives me the error “argument of type ‘NoneType’ is not iterable”.
is thrown out.
Attached is an excerpt from the log, maybe you can figure it out.
BTW: Does anyone know how I can check the lines specified in the error message? or where they are?
Thanks a lot!
2022-07-21 12:51:42 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 222, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/core.py", line 30, in post
errors = await async_check_ha_config_file(request.app["hass"])
File "/usr/src/homeassistant/homeassistant/config.py", line 928, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 233, in async_check_ha_config_file
p_validated = platform_schema(p_validated)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 232, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 351, in _exec
v = func(v)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
return schema(data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 387, in validate_mapping
cval = cvalue(key_path, value)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 541, in verify
return cast(dict, schema(value))
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 229, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 353, in _exec
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 813, in validator
if key in config:
TypeError: argument of type 'NoneType' is not iterable
