I did an incremental backup restore (and possibly that was a mistake) and wanted to check the configuration. yaml through file editor as usual. But the whole configuration folder is gone in file editor.
Through Samba I cannot get into the config folder either.
Everything is running but e. g. in the Esp setting my adapters are not showing up… but the devices are still working…
I had the exact same behavior. Did a partial restore to the Home Assistant part of the backup, and the config folder is now completely empty, including subdirectories like .storage.
I tried that after carefully watching some videos about backup and restore, to better understand the process, but that came as a big surprise. Looks like an undocumented feature to me
I also tried to manually create a file under the config folder, but I get an error “no such file”.
I would also like to understand what is the solution for this…
I’m runnig into the same error. Restoring from a Backup and the config folder is empty.
I also just restarted the SAMBA and the SSH / Terminal Addon, and the Files are back.
Very strange
Edit:
I have the restart ALL addons that have access to the config folder, like Studio Code Server.
Restoring the 2023.4.3 raised this issue about accessing config file. Restarting addons don’t help.
I had to do a full OS restart (restart HA failed as I needed to remove some YAML for an addon I just removed).
