Hi
This script fails if I set the value of “None” for the “effect” (this is the string Hue uses)
variables:
effect: "None"
sequence:
- service: light.turn_on
entity_id: light.lounge_left
effect: "{{ effect }}"
The error is
“Failed to call service script/test_pendant_effects. string value is None for dictionary value @ data[‘effect’]”
It works if I use a different effect string, say effect: “prism”
I can workaround like this
- if:
- condition: template
value_template: "{{ effect == 'None' }}"
then:
entity_id: light.pendant_dining_room
effect: None
else:
but is this a bug?
Is there a way I can pass “None” as a string that won’t trigger this error?
