Hi, I’ve already read other posts and posted my issue on the corresponding GitHub page but I was not able to configure it correctly. My setup ist the following: Debian + Home Assistant (supervised) incl. AddOns (Z2MQTT Edge + MQTT Broker).
I’ve used the auto-discovery function and was able to successfully implement my cover controller which is often called Zenismart, AM43 or TS0601.
However, I cannot set the position of my cover. As soon as I try to move the position slider in my Z2MQTT add-on or in HA, the value in the of state section of my Z2MQTT-add-on changes accordingly, e.g.:
"linkquality": 44,
"motor_speed": 41,
"position": 55,
"running": true,
"state": "OPEN"
but in the end nothing happens.
At least I can close and fully open it when I press the up and down arrows.
MQTT Log:
Info MQTT publish: topic 'zigbee2mqtt/0x5c0272fffeca9dcc', payload '{"linkquality":44,"motor_speed":41,"position":55,"running":true,"state":"OPEN"}'
HA Log says its not an integer but it is!?:
2021-03-16 17:21:48 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'value_json' is undefined (value: , template: {{ value_json.position }})
2021-03-16 17:21:48 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
