Cannot setup samba share
Hi All! I’m trying to setup Samba share but after many attempts I am unable to get it running and visible on my PC.
Here is my configuration:
username: HASS
password: Password
workgroup: WORKGROUP
compatibility_mode: false
veto_files:
  - ._*
  - .DS_Store
  - Thumbs.db
  - icon?
  - .Trashes
allow_hosts:
  - 10.0.0.0/8
  - 172.16.0.0/12
  - 192.168.0.0/16
  - fe80::/10
And with that configuration I get this in my logs
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/samba.sh
[16:43:39] INFO: Hostname: homeassistant
[16:43:40] INFO: Interfaces: eth0 wlan0
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user HASS.
cont-init: info: /etc/cont-init.d/samba.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun nmbd (no readiness notification)
services-up: info: copying legacy longrun smbd (no readiness notification)
s6-rc: info: service legacy-services successfully started
added interface eth0 ip=fdc9:e854:c54d:b5fd:8764:da2:d462:e479 bcast= netmask=ffff:ffff:ffff:ffff::
added interface eth0 ip=192.168.86.39 bcast=192.168.86.255 netmask=255.255.255.0
interpret_interface: Can't find address for wlan0
smbd version 4.16.10 started.
Copyright Andrew Tridgell and the Samba Team 1992-2022
uid=0 gid=0 euid=0 egid=0
nmbd version 4.16.10 started.
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
Processing section "[media]"
INFO: Profiling support unavailable in this build.
making subnet name:192.168.86.39 Broadcast address:192.168.86.255 Subnet mask:255.255.255.0
create_subnets: ignoring non IPv4 interface.
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 192.168.86.39
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 192.168.86.39
run_elections: >>> Won election for workgroup WORKGROUP on subnet 192.168.86.39 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 192.168.86.39
Samba name server HOMEASSISTANT is now a local master browser for workgroup WORKGROUP on subnet 192.168.86.39
Could not find child 155 -- ignoring
To me, I don’t know much yet, it looks like it should be up and running?
But even after enabling network sharing, making hidden objects on the network show, I cannot find this folder.
I have quite a few “other devices” and “Media players” visible on my network, including one called home assistant that when I click on it, it opens a browser with my HASS instance. But nothing that is from samba share.
I’ve watched 4-5 different videos several times, uninstalled, reinstalled, restart, reset, reboot, you name it (the obvious stuff I at least), I’ve probably tried it.
Any help is greatly appreciated.
Your log is very similar to mine so I think it should be running.
How are you trying to access the shares? From a windows machine?
I will say that I have compatibility mode set to true for my instance. It is a slider in the GUI.
Yes, from a windows machine.
I will change the slider and see if that changes anything.
Next step for me is to go into Windows Explorer and then in the address bar at the top I put in the IP address of my Home Assistant. Like this:
\192.168.1.1
Once I click Enter the first time it will come up with a username and password box.
Have you done that OR are you just looking for it to appear in your network?
I’ve gone ahead and done that but “the page cannot be reached 192.168.1.1 took too long to respond”
I double-checked my settings and have also turned off my firewall but no change
What is the IP address of your home assistant?
I put in \192.168.1.1 as an example. You will need to know your actual IP address.
Note the 2 backslashes, and I left off one to start.
Edit: It appears the message board doesn’t like my consecutive backslashes. You will need 2.
\\192.168.1.1
Using preformatted text ( </> symbol from the icon menu) can help
allow_hosts:
  - 10.0.0.0/8
  - 172.16.0.0/12
  - 192.168.0.0/16
  - fe80::/10
  1. Is your IP adressing scheme one of the above?
  2. Can you ping your HA instance? (and get a reply)
  3. Win + R opens the Run dialog box: type in there the IP address preceeded with the double backslash
I was incorrectly inputting the IP address… simple fix but appreciate you walking me through it!
The win + R was very helpful, thank you!
@Harsh_Tone: you can ‘mount’/map as drive this share to a drive letter in windows explorer (easy access in the icon menu)
Win + R was the answer! Thanks
Bob
