I have a py script that should run in Pyscript. I should say that this is not my script and I am not python programmer. However, at the moment I have problem with single error message:
Exception in </config/pyscript/hewalex2mqtt.py> line 5: from hewalex_geco.devices import PCWU, ZPS ^ ModuleNotFoundError: No module named 'hewalex_geco'
the error is caused by the following line
where hewalex_geco.devices are folders where PCWU, ZPS files are located.
Is this Pyscript bug?
As I understand it should work!
Also when I try to use
from .hewalex_geco.devices import PCWU, ZPS
I get:
ImportError: attempted relative import with no known parent package
maybe someone has an idea how to fix this. Is it bug? Or is there syntax error?
