I’ve been strugling for days with this… Cannot start appdaemon addon:
get this error:
18-06-11 20:01:03 INFO (SyncWorker_15) [hassio.docker.interface] Clean hassioaddons/appdaemon3-armhf docker application
18-06-11 20:01:03 INFO (SyncWorker_15) [hassio.docker.interface] Remove docker hassioaddons/appdaemon3-armhf with latest and 1.1.1
18-06-11 20:01:05 INFO (MainThread) [hassio.addons.addon] Remove Home-Assistant addon data folder /data/addons/data/a0d7b954_appdaemon3
18-06-11 20:02:50 INFO (MainThread) [hassio.addons.addon] Create Home-Assistant addon data folder /data/addons/data/a0d7b954_appdaemon3
18-06-11 20:02:50 INFO (SyncWorker_0) [hassio.docker.interface] Pull image hassioaddons/appdaemon3-armhf tag 1.1.1.
18-06-11 20:04:14 INFO (SyncWorker_0) [hassio.docker.interface] Tag image hassioaddons/appdaemon3-armhf with version 1.1.1 as latest
18-06-11 20:05:50 INFO (SyncWorker_12) [hassio.docker.interface] Clean hassioaddons/appdaemon3-armhf docker application
18-06-11 20:05:50 ERROR (SyncWorker_12) [hassio.docker] Can’t create container from addon_a0d7b954_appdaemon3: 409 Client Error: Conflict (“Conflict. The container name “/addon_a0d7b954_appdaemon3” is already in use by container “9f4f226c54c73f503dbb3b8c1a34847f28fa595fdc992bbbc2e0170d49c9a842”. You have to remove (or rename) that container to be able to reuse that name.”)
18-06-11 20:05:52 INFO (SyncWorker_13) [hassio.docker.interface] Clean hassioaddons/appdaemon3-armhf docker application
18-06-11 20:05:52 ERROR (SyncWorker_13) [hassio.docker] Can’t create container from addon_a0d7b954_appdaemon3: 409 Client Error: Conflict (“Conflict. The container name “/addon_a0d7b954_appdaemon3” is already in use by container “9f4f226c54c73f503dbb3b8c1a34847f28fa595fdc992bbbc2e0170d49c9a842”. You have to remove (or rename) that container to be able to reuse that name.”)
18-06-11 20:07:15 WARNING (SyncWorker_11) [hassio.docker.interface] Can’t grap logs from hassioaddons/appdaemon3-armhf: 500 Server Error: Internal Server Error (“can not get logs from container which is dead or marked for removal”)
18-06-11 20:07:16 INFO (SyncWorker_19) [hassio.docker.interface] Clean hassioaddons/appdaemon3-armhf docker application
18-06-11 20:07:16 ERROR (SyncWorker_19) [hassio.docker] Can’t create container from addon_a0d7b954_appdaemon3: 409 Client Error: Conflict (“Conflict. The container name “/addon_a0d7b954_appdaemon3” is already in use by container “9f4f226c54c73f503dbb3b8c1a34847f28fa595fdc992bbbc2e0170d49c9a842”. You have to remove (or rename) that container to be able to reuse that name.”)
I have tried resotring a backup with wipe checked…
Ive tried uninstalling removing all appdaemon configs (appdaemon dir in config) and reinstalling
Always ends up with the same message…
would appreciate any help with this… Hoping to avoid new install
