I’ve cloned the core repository and have a local copy on my machine. I’ve run brew install python3 autoconf ffmpeg cmake make
which all ran successfully.
Following the development guide I’m trying to run script/setup
, but it’s failing with the following:
ERROR: Exception:
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_vendor/packaging/markers.py", line 278, in __init__
self._markers = _coerce_parse_result(MARKER.parseString(marker))
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_vendor/pyparsing/util.py", line 256, in _inner
return fn(self, *args, **kwargs)
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_vendor/pyparsing/core.py", line 1190, in parse_string
raise exc.with_traceback(None)
pip._vendor.pyparsing.exceptions.ParseException: , found '31m' (at char 0), (line:1, col:1)
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_internal/cli/base_command.py", line 180, in exc_logging_wrapper
status = run_func(*args)
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_internal/cli/req_command.py", line 245, in wrapper
return func(self, options, args)
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_internal/commands/install.py", line 342, in run
reqs = self.get_requirements(args, options, finder, session)
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_internal/cli/req_command.py", line 411, in get_requirements
req_to_add = install_req_from_line(
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_internal/req/constructors.py", line 421, in install_req_from_line
parts = parse_req_from_line(name, line_source)
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_internal/req/constructors.py", line 323, in parse_req_from_line
markers = Marker(markers_as_string)
File "/Users/hummingbear/Code/core/venv/lib/python3.11/site-packages/pip/_vendor/packaging/markers.py", line 280, in __init__
raise InvalidMarker(
pip._vendor.packaging.markers.InvalidMarker: Invalid marker: '31m\x1b[Kawesomeversion\x1b[m\x1b[K==23.11.0', parse error at '31m\x1b[Kaw'
When I pick apart script/setup
it’s failing while trying to run python3 -m pip install colorlog pre-commit $(grep awesomeversion requirements.txt) --constraint homeassistant/package_constraints.txt --upgrade
in script/bootstrap
I have tried searching on the relevant exceptions that are raised in the stacktrace. I’ve also tried nuking and re-installing python. I must admit I am not an expert in Python so I’m a little out of my element. What is going on here?
