I’m attempting to configure my first DHCP server, and found the following message when attempting to save the ‘default’, or suggested configuration from ‘home-assistant, addons/dhcp_server’:
not a valid value for dictionary value @ data[‘options’]. Got {‘domain’: ‘mshome.net’, ‘dns’: [‘8.8.8.8’, ‘8.8.4.4’], ‘networks’: [{‘subnet’: ‘192.168.1.0’, ‘netmask’: ‘255.255.255.0’, ‘range_start’: ‘192.168.1.100’, ‘range_end’: ‘192.168.1.200’, ‘broadcast’: ‘192.168.1.255’, ‘gateway’: ‘192.168.1.1’, ‘interface’: ‘eth0’}], ‘hosts’: []}
I’m not sure why the error isn’t more specific, I’ve tried removing one line at at time, but it keeps showing the same error.
I’m using the following configuration, and have entered an arbitrary domain name. I imagine the setting is set here, and can be anything, not having to match an existing one?
I should have checked, but it seems it was ‘translated’ as curly speech marks instead of standard.
" is how it’s shown in the actual configuration. It seems anything pasted converts the text, please see the preformatted text below.
