Since I updated from 0.75.1 to 0.81.5 and I start hass
I get the following error:
Config directory: /home/homeassistant/.homeassistant/
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
2018-11-04 19:23:39 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2018-11-04 19:23:40 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
2018-11-04 19:23:40 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2018-11-04 19:23:40 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2018-11-04 19:23:40 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2018-11-04 19:23:40 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2018-11-04 19:23:40 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger
2018-11-04 19:23:40 INFO (MainThread) [homeassistant.setup] Setting up logger
2018-11-04 19:23:40 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
Exception in thread Recorder:
File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/recorder/__init__.py", line 186, in run
from .models import States, Events
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/recorder/models.py", line 6, in <module>
from sqlalchemy import (
File "/home/homeassistant/.homeassistant/deps/lib/python3.5/site-packages/sqlalchemy/__init__.py", line 9, in <module>
from .sql import (
ImportError: No module named 'sqlalchemy.sql'
Anyone has any idea how to fix this?
I’m running a manual installation of hass on a raspberry pi 3
