Cannot unistall Stock TUYA Plug-In
When i’m trying to unistall the plugin this error on the log shows up
2021-12-25 23:13:13 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 181, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 71, in delete
    result = await hass.config_entries.async_remove(entry_id)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 831, in async_remove
    await entry.async_remove(self.hass)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 487, in async_remove
    component = integration.get_component()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 522, in get_component
    cache[self.domain] = importlib.import_module(self.pkg_path)
  File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "", line 1030, in _gcd_import
  File "", line 1007, in _find_and_load
  File "", line 986, in _find_and_load_unlocked
  File "", line 680, in _load_unlocked
  File "", line 850, in exec_module
  File "", line 228, in _call_with_frames_removed
  File "/usr/src/homeassistant/homeassistant/components/tuya/__init__.py", line 8, in
    from tuya_iot import (
ImportError: cannot import name 'AuthType' from 'tuya_iot' (/usr/local/lib/python3.9/site-packages/tuya_iot/__init__.py)
So, where’s the problem. I cannot unistall the plugin in any way.
Thank you :+1:
