Morning. Just tried it, but with not with the desired outcome unfortunatly. The error message stays the same.
I follow this article here but I logged in root via the dev console (ssh -p 22222 "user@hostname). I do not have access to docker during the normal ssh access as opposed as describbed in that artice here:
This actually is the output when I try to update and after several attempts it just gives up…
sh: 1: udevadm: not found
flash firmware
command reset timeout
query bootloader id V3
query bootloader failed
retry: 38 seconds left
read file success: /tmp/deCONZ/firmware/deCONZ_RaspBeeII_0x26780700.bin.GCF (163244 bytes)
flash firmware
retry: 36 seconds left
flash firmware
command UART reset done
I know this article, I maybe know them all;). Tried that already, isn’t working at all for many reasons. As said, I have a RASPi HA env with docker. Have no package manager, no install toolkit, no docker command within the standard env ect…
Not possible that way.
Regards
