I get this error:
Failed to call service update/install. Error compiling office-presence.yaml; Try again in ESPHome dashboard for more information.
when I try to update:
I get this error:
There are some breaking changes in the update. So you need to change the yaml of ota. See picture above.
Thank you.
I got this message after flashing the update:
[14:33:22][C][ld2410:077]: Firmware Version : 2.04.23022511
[14:33:22][D][binary_sensor:036]: 'Moving Target': Sending state ON
[14:33:22][D][sensor:094]: 'Moving Distance': Sending state 150.00000 cm with 0 decimals of accuracy
[14:33:22][D][sensor:094]: 'Move Energy': Sending state 22.00000 % with 0 decimals of accuracy
[14:33:22][D][sensor:094]: 'Still Distance': Sending state 220.00000 cm with 0 decimals of accuracy
[14:33:22][D][sensor:094]: 'Still Energy': Sending state 33.00000 % with 0 decimals of accuracy
[14:33:22][D][sensor:094]: 'Detection Distance': Sending state 159.00000 cm with 0 decimals of accuracy
[14:33:22][E][ld2410:336]: Error with last command : incorrect Header
[14:33:22][W][component:237]: Component ld2410 took a long time for an operation (74 ms).
[14:33:22][W][component:238]: Components should block for at most 30 ms.
[14:33:22][C][captive_portal:088]: Captive Portal:
[14:33:22][C][mdns:115]: mDNS:
