Cannot update Home Assistant >2022
I have an issue with getting the new version. I have version 2022.12.8
If I chose Settings-System-Updates its informs me that there is no updates
Billede20
How can I update to 2023.04?
I am using Synology/Docker
You would have to update it from synology.
You probably did not install it not from Syno or did you? At least…do not (!) use that one as this is always outdated… use the ‘regular’ docker setup.
Hereby a setup and when you upgrade, you only have to remove the container and re-run the script
BUT… you probably used something else for your current setup and this should be aligned, i.e. else you risk to lose mapping the persistent volume(s)
How to Install Home Assistant on Your Synology NAS – Marius Hosting
EDIT: or…how did you install the current ?
Not using synology here, but however you did/do install it with @vingerha 's help, I recommend you update to the last release of each month one by one before updating to 2023.4 as there’s been lots of db migration etc between those versions
+1
Going for the first of each month risks getting all the bugs of the new release (2023.4 had quite a few)
As far as remember i did installed it in the Synology Docker.
I sounds not easy to upgrade, I must because I have a REOLINK cam.
I will try to go through the Marius Hosting; I remember I used it for my ConBee - and with your help, I checkmark were missing for the ConBee to work :slight_smile:
Hi
I will return with an update, it seems to have succeeded; luckily with a backup I did made.
OK, if you have used the same persistent volume as before, then why the backup? Or did you change volume?
