Cannot update Home Assistant Core. Error updating Home Assistant Core: 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
I cannot update Home Assistant Core. When I try to update I get: Error updating Home Assistant Core: ‘HomeAssistantCore.update’ blocked from execution, system is not healthy - setup
I am running Home Assistant via VirtualBox
I did not install or change anything recently. What could be the issue?
This is what I get in system logs:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:245
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 08:16:20 (4 occurrences)
Last logged: 08:21:56
[140404686282256] Unexpected exception
[140404653484656] Unexpected exception
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 307, in async_install
    await self.coordinator.supervisor_client.homeassistant.update(
        HomeAssistantUpdateOptions(version=version, backup=backup)
  File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/homeassistant.py", line 34, in update
    await self._client.post(
        "core/update", json=options.to_dict() if options else None, timeout=None
  File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/client.py", line 173, in post
    return await self._request(
    ...<7 lines>...
  File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/client.py", line 122, in _request
    raise exc_type(result.message, result.job_id)
aiohasupervisor.exceptions.SupervisorBadRequestError: 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
    response = await hass.services.async_call(
    ...<7 lines>...
  File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
    single_response = await _handle_entity_call(
        hass, entity, func, data, call.context
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 157, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 502, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 311, in async_install
    raise HomeAssistantError(
        f"Error updating Home Assistant Core: {err}"
    ) from err
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core: 'HomeAssistantCore.update' blocked from execution, system is not healthy - setup
Search this forum for “Home assistant core not healthy”
There are a few solutions.
