Cannot update home assistant in venv
Hi all,
I am trying to update home assistant from 2021.2.3 to the latest version using the following commands:
sudo -u homeassistant -H -s
source /srv/homeassistant/bin/activate
pip3 install --upgrade homeassistant
but I get the following error:
ERROR: Could not install packages due to an EnvironmentError: [Errno 13] Permission denied: 'RECORD'
Consider using the `--user` option or check the permissions.
Any suggestion on how to approach the problem? Many thanks!
What version of Python?
@giovanni: you have to stop the running HA
sudo systemctl stop [email protected]
Complete procedure:
sudo su -s /bin/bash homeassistant
exit
sudo systemctl start [email protected]
Python 3.9.1
I tried this procedure but the update still fails :frowning:
You get permission denied Are some of the files owned by root instead of the user running HA?
On @Prodigyplace’s suggestion maybe check something like
find /srv/homeassistant -ls | awk ‘{print $5, $11}’ | grep -v homeassistant
Which is just a (messy) check for any file in ~homeassistant that is not owned by homeassistant. The find should come up empty.
It does come up empty
Now I’m guessing. Perhaps adding some verbosity to the pip3 command will tell us which ‘RECORD’ is the one that’s a problem. Mine look to be all -rw-r–r–
pip3 install -vvv --upgrade homeassistant # and see if anything new is learned
exit
This is the verbose output:
ERROR: Could not install packages due to an EnvironmentError.
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_internal/commands/install.py", line 397, in run
    installed = install_given_reqs(
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_internal/req/__init__.py", line 99, in install_given_reqs
    uninstalled_pathset.commit()
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_internal/req/req_uninstall.py", line 450, in commit
    self._moved_paths.commit()
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_internal/req/req_uninstall.py", line 290, in commit
    save_dir.cleanup()
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_internal/utils/temp_dir.py", line 199, in cleanup
    rmtree(ensure_text(self._path))
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_vendor/retrying.py", line 49, in wrapped_f
    return Retrying(*dargs, **dkw).call(f, *args, **kw)
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_vendor/retrying.py", line 212, in call
    raise attempt.get()
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_vendor/retrying.py", line 247, in get
    six.reraise(self.value[0], self.value[1], self.value[2])
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_vendor/six.py", line 703, in reraise
    raise value
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_vendor/retrying.py", line 200, in call
    attempt = Attempt(fn(*args, **kwargs), attempt_number, False)
  File "/srv/homeassistant/lib/python3.9/site-packages/pip/_internal/utils/misc.py", line 138, in rmtree
    shutil.rmtree(dir, ignore_errors=ignore_errors,
  File "/usr/local/lib/python3.9/shutil.py", line 718, in rmtree
    _rmtree_safe_fd(fd, path, onerror)
  File "/usr/local/lib/python3.9/shutil.py", line 675, in _rmtree_safe_fd
    onerror(os.unlink, fullname, sys.exc_info())
  File "/usr/local/lib/python3.9/shutil.py", line 673, in _rmtree_safe_fd
    os.unlink(entry.name, dir_fd=topfd)
PermissionError: [Errno 13] Permission denied: 'RECORD'
WARNING: You are using pip version 20.2.4; however, version 21.1.3 is available.
You should consider upgrading via the '/srv/homeassistant/bin/python3 -m pip install --upgrade pip' command.
Removed build tracker: '/tmp/pip-req-tracker-3dsmw2kb'
Apparently, you need to upgrade pip:
sudo pip3 install --upgrade pip
Source:
Permision problem pip (python-forum.io)
Success!!! I had to update pip through:
Thank you all for helping :slight_smile:
