Here is my program:
esphome:
friendly_name: Button2
comment: Remote Button
esp32:
board: esp32dev
#framework:
#type: arduino
packages:
base: !include { file: A_package/basic.yaml, vars: { uptime_update_inverval: 10sec }}
And the package that I use for all my ESP devices.
```# This is the package used in all my Esphome Devices
# FOLLOWINGS Substitutions MUST be defined
# - devicename : This is used to define the SSID name
# - esp_id : This used a prefix to all entities name
# - Uptime_update_inverval : This used to determine update interval
esphome:
# Enable logging
logger:
api: # Enable Home Assistant APIx API is used to communicate directly with Home Assistant
# encryption:
# key: !secret encryption_key
ota: #Enable OverTheAir ota update
- platform: esphome
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
ap: # Enable an access point mode on the node in case wifi connection fails
ssid: ${devicename}
password: !secret ap_wifi_password
captive_portal: # component is a fallback mechanism for when connecting to the configured WiFi fails
switch:
- platform: restart # To restart your node remotely through Home Assistant.
- platform: shutdown # To shutdown when the battery is below the minimu, level
- platform: wifi_signal # Read the signal strength of the currently connected WiFi Access Point
name: "WiFi Signal" # wifi force
update_interval: 5min # update every 5 minutes
binary_sensor:
- platform: status
entity_category: diagnostic
text_sensor: # Text Sensor with general information
- platform: wifi_info # Expose WIFI information
ip_address:
ssid:
bssid:
mac_address:
name: Mac Wifi Address
icon: mdi:clock-start
update_interval: ${uptime_update_inverval}
lambda: |-
auto s = millis() / 1000;
return str_snprintf("%02d:%02d:%02d:%02d", 11, s / 86400, s / 3600 % 24, s / 60 % 60, s % 60);
output:
light:
web_server:
port: 80
I can compile my program and upload when connected to my Rasberry Pi. Then I can “Visit” it and LOGS Wirelessly.
However when I try to install it wirelessly, It compile and upload when stop there. Here is the log:
INFO ESPHome 2024.6.1
INFO Reading configuration /config/esphome/button2.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing button2 (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.3
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- ArduinoJson @ 6.18.5
RAM: [= ] 12.4% (used 40788 bytes from 327680 bytes)
Flash: [===== ] 49.4% (used 905657 bytes from 1835008 bytes)
========================= [SUCCESS] Took 17.87 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 10.0.0.249
INFO Uploading /data/build/button2/.pioenvs/button2/firmware.bin (911536 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 11.18 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 10.0.0.249 using esphome API
WARNING Can't connect to ESPHome API for button2 @ 10.0.0.249: Timeout while connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='10.0.0.249', port=6053))] (TimeoutAPIError)
INFO Trying to connect to button2 @ 10.0.0.249 in the background
Text
I remove the device from ESPhome integration and reinstalled it. Without succes.
Any ideas to get it to work !
