Cannot update Supervisor, unexpected commit digest
Have installed the Oracle VM VirtualBox on a PC running Zorin (Ubuntu).
Had some initial trouble updating Supervisor due to DNS issues. Got that fixed.
Now I get this error when attempting to update Supervisor:
2026-11-20 13:23:59.110+01:00 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
2026-11-20 13:23:59.177+01:00 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
2026-11-20 13:23:59.288+01:00 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2026.11.0
2026-11-20 13:24:01.296+01:00 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2026.11.0.
2026-11-20 13:24:05.245+01:00 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core installation in progress
2026-11-20 13:24:05.411+01:00 ERROR (MainThread) [supervisor.docker.manager] failed commit on ref "layer-sha256:d2b3247c142d41b9e4b99b5ac19dcca45d2890db72163f624e0afe35fc35466a": commit failed: unexpected commit digest sha256:aa67f2fa82948d46fbf156b73c3d3dbe5d97bbdbe99f675e0e029234ab682890, expected sha256:d2b3247c142d41b9e4b99b5ac19dcca45d2890db72163f624e0afe35fc35466a: failed precondition
2026-11-20 13:24:05.412+01:00 CRITICAL (MainThread) [supervisor.supervisor] Update of Supervisor failed: failed commit on ref "layer-sha256:d2b3247c142d41b9e4b99b5ac19dcca45d2890db72163f624e0afe35fc35466a": commit failed: unexpected commit digest sha256:aa67f2fa82948d46fbf156b73c3d3dbe5d97bbdbe99f675e0e029234ab682890, expected sha256:d2b3247c142d41b9e4b99b5ac19dcca45d2890db72163f624e0afe35fc35466a: failed precondition
Is there anything I can to get passed this point?
What installation type and version are you running of HA?
HA OS version 18.4
Running in a VirtualBox on a Zorin (Ubuntu) computer.
Both were freshly downloaded and installed yesterday.
Supervisor and Core are currently version 26.10. Both want to update to 26.11 before I can get to use them…
It might be because your connection is closed prematurely.
Is your ISP connection stable?
If it is a wireless/mobile connection then a drop in the connection can mean you get a new IP and then the connection starts over.
Do you have a proxy in between you and the internet or do your ISP use one?
A proxy might not handle keep alive connections that well.
I have a very stable 300 mbps fiber connection. The computer has cabled connection to the router. No issues on that front.
Are you SURE about that?
Well, given that it downloads the packages, I am pretty sure. The error happens when it tries to install the downloaded package. The message shows a difference in the sha256 value. I get the same values on every attempt. That suggests that I can download the same package every time but it does not match the expected value. I may be wrong but I would think that either the package has been tampered with or the local system fails when comparing.
I have set 86.54.11.100 and 86.54.11.200 as DNS servers. That is the unfiltered resolution on DNS4EU.
18.4 gave me issues. I went back to 18.3 and it fixed my VM issues and still using it!
Well, I scrapped the first installation, downloaded the .vdi again. This time it came with the 2026.11.2 version and no need to update. So, Home Assistant is up and running.
Thanks for your input :slight_smile:
trying to install “Generic x86-64 PC” to exclusively run HA on older Lenovo HW using 18.4 image. Have the same errors on digest, running into a loop:
026-11-24 16:09:50.827+01:00 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core installation in progress
2026-11-24 16:09:56.890+01:00 ERROR (MainThread) [supervisor.docker.manager] failed commit on ref “layer-sha256:8bd0057318afd7a881335cf6f0c31c6393aa22e60512610a456e5e1880a67773”: commit failed: unexpected commit digest sha256:4fe9e035892f71c6e41b5583a6bbb7e530a8e3830f4f76bfb3abdbb6848ded2c, expected sha256:8bd0057318afd7a881335cf6f0c31c6393aa22e60512610a456e5e1880a67773: failed precondition
2026-11-24 16:09:56.891+01:00 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
