Cannot update to 0.101.0 from 0.100.3
Hello!
Host system;
Host system
|System|HassOS 3.5|
|Deployment|staging|
Based on rPi3.
Hass.io supervisor
|Version|192|
|Latest version|192|
Trying to upgrade version of homeassistant from 100.3 to 101, but getting this errors before reboot:
19-10-31 06:24:37 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.101.0
19-10-31 06:24:37 INFO (SyncWorker_14) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.100.3 to homeassistant/raspberrypi3-homeassistant:0.101.0
19-10-31 06:24:37 INFO (SyncWorker_14) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.101.0.
19-10-31 06:27:13 ERROR (MainThread) [hassio.utils] Can't execute update while a task is in progress
19-10-31 06:30:08 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-10-31 06:32:01 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-10-31 06:32:05 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-10-31 06:32:06 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-10-31 06:32:16 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
19-10-31 06:32:39 INFO (MainThread) [hassio.store] Load add-ons from store: 61 all - 0 new - 0 remove
and after loading homeassistant:
19-10-31 06:49:00 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-10-31 06:49:00 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.100.3
19-10-31 06:49:01 INFO (SyncWorker_14) [hassio.docker.interface] Cleanup images: ['homeassistant/raspberrypi3-homeassistant:0.101.0']
19-10-31 07:12:01 INFO (MainThread) [hassio.host.info] Update local host information
19-10-31 07:12:01 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-10-31 07:12:01 INFO (MainThread) [hassio.host.services] Update service information
19-10-31 07:12:01 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-10-31 07:12:02 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-10-31 07:12:02 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-10-31 07:25:09 INFO (MainThread) [hassio.api.security] /supervisor/logs access from core_ssh
Any ideas?
Had the same problem with updating, got it fixed:
  • Backup config.yaml (to maybe config.yaml.bak)
  • create a very basic config.yaml - like the default_config part only
  • restart home assistant
  • do the upgrade, should work now
  • move the backup-config back to origin place
  • do a config-check
This way you will at least find out if there is something wrong with your config…
Thanks, @grangnwochnfohra, it helps. Api password that was in config causes upgrade fail.
Thanks @grangnwochnfohra and @koznov
My problem was the Api Key from Owntracks
I tried the update this morning 1/11/19 and RPi 3 just sat there for ages (30-40 mins) and there was no activity. Pi had lost IP address so I assumed Pi was totally hung so I reboot.
System came back up as the previous 0.100.3
but system seems confused as to what is latest version …see below
Very confused.
I am only using the GUI interface.
If you take a look at the logs under system it might say something with rollback (in yellow or red I think). Failing with the update will let the system boot the old version.
Maybe you might want to try the workaround from above. If you use only the web GUI you can also comment your whole config, reducing it to the default config part.
Thanks for the reply.
I checked the log and the only yellow was some warning
19-10-31 21:59:17 WARNING (MainThread) [hassio.dns] Ignore invalid DNS Server: dns://2001:8003:f00f:9f00::1
I had no idea where this came from but it looked like an IP6 address so I checked my WAN IP and it has this IP6 address in the service provider’s DHCP section of my router???
Beats my poor brain :smiley:
Yes I can fiddle with the config as suggested but I really was trying to just use the GUI and set it up so that other family members who have less skills could operate it.
I had a look at the release notes and there is not much that I think I need so might wait and see what transpires.
I was hoping the system was a bit more robust for less skilled users.
Those are two different things.
Your second screenshot is of the Hass.io superviser and not Home Assistant itself.
It’s bit supervisor but dns
Hm, seems like your hass.io installation has taken the v6-DNS-server from your provider. But I would say thats normal and this warning shouldn’t prevent from updating. Any errors?
Do you have an api-key defined in your config? If so please comment it, reboot and then try it again.
No, No API key.
Only key is HEX KEY for my Z-Wave USB Stick
This is my Config so far. I am a newby at all this so it’s pretty straight forward
I have xxx’ed out username/passwords/IPV4
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
## Camera configuration.yaml entry
#camera: !include cameras.yaml
#Front DoorCam
binary_sensor:
   - platform: hikvision
     host: 192.168.0.x
     username: xxx
     password: xxx
#ShedCam
     host: 192.168.0.x
     username: xxx
     password: xxx
#BackDoorCam
     host: 192.168.0.x
     username: xxx
     password: xxx
 # Enphase Envoy configuration.yaml entry, limiting the metrics to production only
  - platform: enphase_envoy
    ip_address: 192.168.0.x
    monitored_conditions:
      - production
      - daily_production
      - seven_days_production
      - lifetime_production
# Moons Phase Sensor
  - platform: moon
# Synology DSM216II
  - platform: synologydsm
    host: 192.168.0.x
    username: xxx
    password: xxx
      - cpu_total_load
      - memory_real_usage
      - network_up
      - network_down
      - volume_status
      - disk_status
      - disk_smart_status
      - disk_temp
# ZWave
zwave:
    usb_path: /dev/ttyACM0
    network_key: "0x24, 0xcb, 0x1d, 0xa3, 0x5c, 0xfa, 0x00, 0x7b, 0x7d, 0xa2, 0xb8, 0xa9, 0x5c, 0xc6, 0xac, 0xeb"
# Example configuration.yaml entry
stream:
I am running Areila Android app on my Samsung s10e but don’t know what effect this would have.
This is what my dashboard looks like at 0.100.3
My automations are
  • using the Line crossing on one of my cameras to turn on/off an LED LAMP between sunset and sunrise
  • same camera but send a notification to Ariela when it’s between sunrise and sunset.
  • simple turn on/off of LED lamp for 2.5 hours after sunset +1 hr
I have not tried another update at this stage
I have run the check config in "Server Control’ and all good.
Anyway, If anything silly that I have done jumps out, let me know.
I will try fiddling next week when I have more spare time but as I cannot see what I have done that is overly complicated.
Thanks for your help.
Have you looked at this?
Hassio cannot update
Well after reading and researching I really could not diagnose what the problems was so I took the following steps.
  1. I thought it might be disk space so I installed ssh and did a df and there was only 20% of the 16GB SD card used or 80% free. Did not look like a disk space issue?
  2. The /dev/root was at 100% so I thought I would get a 32GB (as recommended, I was only using a 16GB) and rebuild. This was a great way to practise recovery as well.
I then took a snapshot of my old system and stored it on my PC.
I downloaded the latest image and burned it to the 32GB Micro SD, plugged it in and waited the 20 minutes until it came up.
  1. I followed the initial install instructions until it was ready to use. Next I installed samba so that I could import the snapshot.
    The big trick was to only do a selected restore as I did not want the old system and old samba.
This brought all my settings back and I was on the latest 0.101.2.
It also taught me how to maintain the system in case of a Micro SD failure.
Hopefully future updates will work.
Just for completeness this is the disk space on the 32GB. The /dev/root is still at 100%. Not being an big expert in unix or this image I am at a loss to explain this.
*core-ssh:~# df*
*Filesystem           1K-blocks      Used Available Use% Mounted on*
*overlay               29941192   1638416  26763756   6% /*
*tmpfs                    65536         0     65536   0% /dev*
*tmpfs                   474184         0    474184   0% /sys/fs/cgroup*
*/dev/root                92416     92416         0 100% /dev/init*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /addons*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /backup*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /share*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /data*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /config*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /ssl*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /etc/resolv.conf*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /etc/hostname*
*/dev/mmcblk0p8        29941192   1638416  26763756   6% /etc/hosts*
*shm                      65536         0     65536   0% /dev/shm*
*tmpfs                    65536         0     65536   0% /proc/keys*
*tmpfs                    65536         0     65536   0% /proc/latency_stats*
*tmpfs                    65536         0     65536   0% /proc/timer_list*
*tmpfs                    65536         0     65536   0% /proc/sched_debug*
*tmpfs                   474184         0    474184   0% /sys/firmware*
Now I can move on the next stage of figuring out how to use the ZW120 door sensor.
is there anyway to sticker you solution? it worked too well…
When trying to upgrade from 0.100.3. to 0.101.3 I get the following error:
Client error on WebSocket API Cannot connect to host xxx.xxx.xxx.xxx:8123 ssl:False [Connection refused].
WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home Assistant startup!
CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
same issue, followed fix provided by Oliver and working now on raspi. Just had to re-run certbot to update python and certificate for ssl to work again.
Guys i dont have any Api password and there is a lot of space left on my device
But getting this error and unable to update
19-12-14 16:18:15 ERROR (SyncWorker_4) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.103.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:51777->[::1]:53: read: connection refused”).
19-12-14 16:18:15 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
