I am currently running HA V81.5 under HASSIO and trying to update to version 82.1, but I keep getting the following error reported:
18-11-20 23:58:05 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.82.1 18-11-20 23:58:05 INFO (SyncWorker_7) [hassio.docker.interface] Update Docker 0.81.5 with homeassistant/raspberrypi3-64-homeassistant:0.82.1 18-11-20 23:58:05 INFO (SyncWorker_7) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-64-homeassistant tag 0.82.1. 18-11-20 23:58:06 ERROR (SyncWorker_7) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-64-homeassistant:0.82.1 -> 500 Server Error: Internal Server Error (“readlink /var/lib/docker/overlay2/l: invalid argument”). 18-11-20 23:58:06 WARNING (MainThread) [hassio.homeassistant] Home Assistant is already running! 18-11-20 23:58:06 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.82.1
Anyone else having this issue or know of a workaround?
