I’ve tried again a “ha core check”. There are a few issues that I am aware of:
- ble monitor integration;
- one ESPHome is annotating A for energy;
Could they be the culprit?
Then there are timeouts … this I cannot solve it seems.
Home Assistant Core
2024-03-14 09:19:49.336 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ble_monitor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-14 09:19:49.340 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-14 09:20:14.346 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2024-03-14 09:20:14.347 WARNING (MainThread) [homeassistant.setup] Setup of bluetooth is taking over 10 seconds.
2024-03-14 09:20:37.715 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform history_stats is taking over 10 seconds.
2024-03-14 09:20:37.716 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2024-03-14 09:20:37.716 WARNING (MainThread) [homeassistant.setup] Setup of schedule is taking over 10 seconds.
2024-03-14 09:20:37.716 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2024-03-14 09:20:37.717 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2024-03-14 09:20:37.717 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2024-03-14 09:20:37.717 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2024-03-14 09:20:37.717 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2024-03-14 09:20:42.803 WARNING (MainThread) [homeassistant.setup] Setup of application_credentials is taking over 10 seconds.
2024-03-14 09:20:42.803 WARNING (MainThread) [homeassistant.setup] Setup of assist_pipeline is taking over 10 seconds.
2024-03-14 09:22:09.473 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: mobile_app, esphome
2024-03-14 09:22:13.257 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.easunmppt_pv_current_calculated (<class ‘homeassistant.components.esphome.sensor.EsphomeSensor’>) is using native unit of measurement ‘A’ which is not a valid unit for the device class (‘energy’) it is using; expected one of [‘kWh’, ‘Wh’, ‘MWh’, ‘MJ’, ‘GJ’]; Please update your configuration if your entity is manually configured, otherwise create a bug report at Issues · home-assistant/core · GitHub
2024-03-14 09:30:09.830 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-03-14 09:30:09.833 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-03-14 09:30:09.837 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-03-14 09:30:09.838 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-03-14 09:30:09.839 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-03-14 09:30:09.840 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-03-14 09:30:09.844 WARNING (MainThread) [homeassistant.components.hassio] Can’t read Supervisor data:
2024-03-14 09:30:33.828 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /ingress/validate_session request
2024-03-14 09:30:33.829 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /ingress/validate_session -
2024-03-14 09:30:38.829 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-03-14 09:30:38.833 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-03-14 09:30:38.835 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-03-14 09:30:38.836 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-03-14 09:30:38.840 ERROR (MainThread) [homeassistant.components.hassio] Error fetching hassio data: Error on Supervisor API:
2024-03-14 09:30:44.828 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /ingress/session request
2024-03-14 09:30:44.829 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /ingress/session -
2024-03-14 09:35:10.599 WARNING (MainThread) [homeassistant.components.systemmonitor.sensor] Updating systemmonitor took longer than the scheduled update interval 0:00:15
2024-03-14 09:35:20.829 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-03-14 09:35:20.832 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-03-14 09:35:20.834 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-03-14 09:35:20.835 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-03-14 09:35:20.837 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-03-14 09:35:20.840 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-03-14 09:35:20.848 WARNING (MainThread) [homeassistant.components.hassio] Can’t read Supervisor data:
2024-03-14 09:35:49.828 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_vscode/changelog request
2024-03-14 09:35:49.829 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch changelog for a0d7b954_vscode:
2024-03-14 09:35:49.832 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_configurator/changelog request
2024-03-14 09:35:49.833 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch changelog for core_configurator:
2024-03-14 09:36:00.830 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/info request
2024-03-14 09:36:00.831 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch info for core_ssh:
2024-03-14 09:36:00.834 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_configurator/info request
2024-03-14 09:36:00.835 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch info for core_configurator:
2024-03-14 09:36:00.837 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_vscode/info request
2024-03-14 09:36:00.838 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch info for a0d7b954_vscode:
2024-03-14 09:40:31.829 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-03-14 09:40:31.832 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-03-14 09:40:31.834 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-03-14 09:40:31.836 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-03-14 09:40:31.838 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-03-14 09:40:31.840 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-03-14 09:40:31.842 WARNING (MainThread) [homeassistant.components.hassio] Can’t read Supervisor data:
