I am stuck. I’ve been using this Z-Wave setup for quite awhile, but now if I upgrade Z-Wave JS to MQTT, Z-Wave breaks and I have been unable to figure out why. I have been through 3 or 4 upgrade/restore cycles trying to track this down.
The same thing (it seems) happens whether I upgrade just the add-on, or upgrade both HA Core and the add-on (and I can’t upgrade just HA Core, because the newest core is incompatible with the older 0.26 version of the add-on…so essentially I am totally stuck on core upgrades until I solve this).
After upgrading the add-on, Z-Wave devices become unaccessible. The Z-Wave JS integration shows an error:
Cannot connect to host a0d7b954-zwavejs2mqtt:3000 ssl:default [Connect call failed ('172.30.33.1', 3000)]
The Z-Wave JS control panel shows nothing:
Here is what is in the Z-Wave JS to MQTT log…it looks like it’s having trouble initializing the controller driver? I have an Aeon Z-Stick (gen 5):
Add-on version: 0.32.0
You are running the latest version of this add-on.
System: Home Assistant OS 7.0 (amd64 / qemux86-64)
Home Assistant Core: 2021.12.1
Home Assistant Supervisor: 2021.12.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] configuration.sh: executing...
[cont-init.d] configuration.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[12:21:22] INFO: Starting the Z-Wave JS to MQTT...
/bin/sh: git: not found
2021-12-15 12:21:24.267 INFO APP: Version: 6.1.0
2021-12-15 12:21:24.270 INFO APP: Application path:/opt
______ _ ___ _ _
|___ / (_) |__ \ | | | |
/ /_ ____ ___ _____ _ ___ ) |_ __ ___ __ _| |_| |_
/ /\ \ /\ / / _` \ \ / / _ \ / __| / /| '_ ` _ \ / _` | __| __|
/ /__\ V V / (_| |\ V / __/ \__ \/ /_| | | | | | (_| | |_| |_
/_____|\_/\_/ \__,_| \_/ \___| |___/____|_| |_| |_|\__, |\__|\__|
_/ | | |
|__/ |_|
2021-12-15 12:21:24.288 WARN STORE: scenes.json not found
2021-12-15 12:21:24.330 INFO APP: Listening on port 44920 host 0.0.0.0 protocol HTTP
2021-12-15 12:21:24.375 INFO MQTT: MQTT is disabled
2021-12-15 12:21:24.384 INFO ZWAVE: Connecting to /dev/serial/by-id/usb-0658_0200-if00
[12:21:24] INFO: Starting NGinx...
2021-12-15 12:21:24.449 INFO ZWAVE: Zwavejs usage statistics ENABLED
2021-12-15 12:21:29.656 INFO ZWAVE: Controller status: Driver: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
at Driver.sendMessage (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:3345:23)
at ZWaveController.identify (/opt/node_modules/zwave-js/src/lib/controller/Controller.ts:673:33)
at Driver.initializeControllerAndNodes (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:975:26)
at Immediate.<anonymous> (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:855:16) (ZW0100)
2021-12-15 12:21:29.659 INFO ZWAVE-SERVER: Server closed
2021-12-15 12:21:29.715 INFO ZWAVE: Client closed
2021-12-15 12:21:29.719 INFO ZWAVE: Connecting to /dev/serial/by-id/usb-0658_0200-if00
2021-12-15 12:21:29.735 INFO ZWAVE: Zwavejs usage statistics ENABLED
2021-12-15 12:21:34.628 INFO ZWAVE-SERVER: Server closed
2021-12-15 12:21:34.683 INFO ZWAVE: Client closed
2021-12-15 12:21:34.689 INFO ZWAVE: Connecting to /dev/serial/by-id/usb-0658_0200-if00
2021-12-15 12:21:34.703 INFO ZWAVE: Zwavejs usage statistics ENABLED
2021-12-15 12:21:39.483 INFO ZWAVE-SERVER: Server closed
2021-12-15 12:21:39.528 INFO ZWAVE: Client closed
2021-12-15 12:21:39.531 INFO ZWAVE: Connecting to /dev/serial/by-id/usb-0658_0200-if00
2021-12-15 12:21:39.538 INFO ZWAVE: Zwavejs usage statistics ENABLED
2021-12-15 12:21:44.327 INFO ZWAVE-SERVER: Server closed
Restarting HA and rebooting the whole server after the upgrades has not solved the issue.
