Hey!
Im setting up a Aqara H1 double rocker wireless, i can discover it and add it, but it only has identify and battery enties. I miss all the button press stuff. I’ve read over multiple other topics but have not found a solution.
identify
battery
Anyone else have this problem?
If you use ZHA, button press will typically be exposed as events, not entities.
Can you please elaborate? See the two options I have here, battery and identify.
There should be more right? Like doubble press, left press, right press etc.
Just have a look at that blueprint. Actually, if you just want to have it working, just use it
