Hi, I am newbie with HA, but I am a programmer and system engineer.
I am little bit confused about Zigbee2MQTT configuration. I installed current HA OS, Mosquitto broker and Zigbee2MQTT addons from the store and git repo. I read the documentation and I know, that new version of MQTT broker do not accept connections without authentication and username and password needs to be set.
I set credentials to MQTT broker same as Zigbee2MQTT.
MQTT broker running ok, but cannot start Zigbee2MQTT addon with error in the log:
Zigbee2MQTT:error 2023-06-14 10:39:37: MQTT error: Connection refused: Not authorized
Broker logs the appropriate error in the log too:
2023-06-14 10:39:37: New connection from 172.30.33.1:32878 on port 1883. error: received null username or password for unpwd check
When I check the broker via external application MQTT Explorer using credentials, everything works very well.
I made a little test with network packet sniffer using virtual external MQTT server and it looks like the Zigbee2MQTT addon does not send ANY credentials at all.
Packet from MQTT Explorer and from Zigbee2MQTT:
Msquitto broker settings:
logins:
- username: *****
password: *****
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
Zigbee2MQTT settings:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
username: ****
password: ****
server: mqtt://core-mosquitto:1883
serial:
port: /dev/ttyACM0
zigbee_herdsman_debug: false
Does anybody kick me with an idea, what I am doing wrong?
Thank you very much.
Home Assistant 2023.6.1
Supervisor 2023.06.1
Operating System 10.2
Frontend 20230608.0 - latest
Mosquitto broker 6.2.1
Zigbee2MQTT 1.31.2-1
